Question about Epson Perfection 3170 Flatbed Scanner
No light when scanner turns on; can bulb be replaced? where to buy?
Can I replace the white cold cathode fluorescent bulb on my EPSON 3170 scanner? Where can I buy a new bulb?
    Scholar:
  • 134 Answers
Unfortunately the bulb on the scanner is not available on retail stores. Epson does not allow end users to take the scanner apart because they might not be able to put the scanner back in together because of the scanner's engineering design.
Please log on to support.epson.com. Click on help me find a service center to the right of the page to search for an epson certified servicer near to your area.
Posted on May 13, 2009
I had the same problem, I know this is late to this post but if anyone else is having this problem, this is what I did to get my lamp to come back to life after trying everything I could think of. I simply reloaded the software for the Epson 3170 and it worked again like the day I bought it.
Posted on Dec 03, 2012
Where can I find the CCFL lamps?
home depot, but they are doing away with them and replace them with LED. The reason is because of the mercy in the bulb.
Apr 28, 2015 | Dell E173FP 17" LCD Monitor
I need a replacement screen and i'm not sure which cffl/backlight to order
Here are the eBay search results for your exact system model -
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=Toshiba+Satellite+L355D-S7809+screen&_sacat=0
Sep 20, 2012 | Toshiba Satellite L355D-S7809 NoteBook AMD...
Does a LCD tv have a bulb in it
Sir lcd has a CCFL it is Cold Cathode Fluorescent lamp and it is powered by the inverter, this light needs a high voltage, the input supply for the inverter board is 24 volts dc. Good day and best regards.
Aug 30, 2011 | Televison & Video
The scanner is connected properly and I've used it for years. I turned on the scanner today and the power button on front lights green, then I hear a jerking sound and the light immediately starts...
Check if the transportation lock is in the unlocked position; this is on the back above the USB port. Disconnect any accessories that could be malfunctioning. Then turn the unit off and back on. If the unit responds properly, it was a temporary problem. Retry the accessories. Otherwise, the unit needs service. You will need to determine if the cost of service is worthwhile.
The flashing red light can indicate the fluorescent lamp needs to be replaced or the scanner is malfunctioning. From the sound you describe, I suspect it could be a problem with the motor or the path that the scanning unit has to travel.
I hope this helps.
Feb 11, 2011 | Epson Perfection 3170 Flatbed Scanner
Suddenly doesn't warm up epson 3170 and windows says it is malfunctioning.
Sounds like the bar inside off the scanner isn't working properly, if thats the case then that means the scanner is bad and it would need to be replaced.
Only thing you can try would be to unplug the scanner for about 5 minutes and then plug it back in. Then turn it on and see if it can initialize properly. If it still cant then you know the scanner is bad for sure.
Jul 05, 2010 | Epson Perfection 3170 Flatbed Scanner
I have power and sound..no picture
smcclain2, Might be a possible failure of the electronic "ballast" circuit that provides 600 to 1000volts AC to light-up the "cold-cathod-fluorescent-lamps" (CCFL's) hung on rear of the glass lcd panel and provide white light so you can see what is on the panel!! The "ballast" is called an "INVERTER". DCv to AC The new energy efficient curlie-Q screw-in light bulbs use a CONVERTER type ballast. AC to AC. You or ccfl back-lit monitor technician will need to troubleshoot and repair the ballast circuit board. Same "lighting technology" is used in 98 percent of all lcd computer monitors. 12fixlouie
May 18, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
Epson Perfection 3170 scanner will not turn on.
having the scanner repaired will cost more than a new one.
Sep 07, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Scanner Perfection 3170 can I down load a
Go here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25021&prodoid=35836301
Aug 31, 2009 | Epson Perfection 3170 Flatbed Scanner
3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Acer AL 1715 monitor flashes 2x and dies
LCD panels use cold-cathode fluorescent bulbs to make the light necessary for them to show images. What you're describing is something I've seen in panels where the bulbs were dying or dead. it's also possible that the controller for the bulbs is also on the fritz.
Jan 08, 2009 | Acer AL1715 17" LCD Monitor
Epson Perfection 3170 Flatbed Scanner Logo
1,290 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
