My release for the gas tank will not open so went throgh the trunk to open it up and im not sure were the fuse is to change it
SOURCE: gas tank won't open, trunk won't open, radio stopped working, left tail lamp won't work
I have the same car with the same problems except for the tail light. My radio works when it wants. This morning I went out and my trunk was open and now it will not stay closed. I dont know what to do. I have no idea where to start with fixing the radio. Did you ever find a solution.
SOURCE: trunk wont open
I have a DeVille also, so if I had the siezed problem I would get a can of Blaster from Auto Zone and give it a good squirt then work with it. After getting it open spray Lock Wrench Silicone spray into it, because it did happen to me from lack of using the darn key.
SOURCE: 1999 catilac deville fuse for trunk blowed dont have key how do y
There is no key hole at all for the trunk, or you just don't have a key? I guess if there is no key, your only option is to remove the back seat, and go through that way. If it's just a missing key, take your car to any GM dealership, and they can cut a key using your VIN number. You can't turn the emblem on the trunk to access a key hole like they used to be?
