Question about Car Audio & Video
Dont no witch why my fuel tap shud be pointing?
Is my furl tap on my aprilia 125rs open when it is pointin 2 my lights on 2 my back wheel?
    Problem Solver:
  • 16 Answers
Try to line up the notch
Posted on Aug 09, 2009
Won't start!!!!!!!
Is there fuel in the tank?
Jun 21, 2013 | 2006 Aprilia RS 125
Have a 2002 125rs aprillia while riding it it wudn go over 40mph then lost all revs now wont fire up when trying to start it it sounds as if i tryn to turn over but wont fire up
Hi, Dannymorrison the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, O2, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty Fuel Pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2002 Aprilia Rs 125
Jul 31, 2011 | 2002 Aprilia RS 125
Am going to fit my clutch cable on my aprilia 125rs is there any problems i might find when am doing this
hi fit it exactly the same way as the old one it will need adjusting after fitting you must have free play at the lever otherwise the clutch will slip about 5ml should do it you may have to compress clutch operating arm to get cable on to lever but its an easy job
May 25, 2010 | 2000 Aprilia RS 125
Aprilia habana cutting out and starting problems
Did you clean the pilot & main jets in the carb & set the float height to standard? There is also an over flow in the carb which should stop fuel flooding into the air filter - did you check?
Make sure there are no splits in the fuel pipes & the smaller vacuum pipe that goes from the side of the auto fuel tap, also check pipes connect well
By your description it sounds like the carb is filling very slowly, 1 bowlful would get you around 2 miles & then plug would be dry when trying to start it, leaving it overnight the carb would fill up & flood air filter due to a leaky fuel tap
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
Apr 22, 2010 | 2004 Aprilia Mojito Custom 150
No fuel to the carburettor
hi mate first off all i would start from the on off tap disconnect fuel line from carb turn tap on and see if anything comes out if not on some carbs on aprilias have a mesh filter behind where the fuel line connects worth checking if clear check the jets are clear in bottom of carb and the float not stuck
Mar 15, 2010 | Aprilia Mojito Custom 125 Motorcycles
No spark from spark plug even with new one bike sometimes stops running cuts out all of sudden 125rs
could be your coil is Faulty, see if you can borrow a coil from another bike and try that..
Oct 25, 2009 | 2002 Aprilia RS 125
2002 aprilla 125rs lossing water
Replacing the water pump assy should fix the problem.
Its the water pump seal thts gone!
Good luck.
Knight . ( Yamaha Seca XJ750A 1981)
Apr 18, 2009 | 2002 Aprilia RS 125
Fuel tap
by fuel tap i take it you mean to select between the reserve tank, and to switch the fuel off... on from 'new shape' models (2006 onwards) there is no switch: it has a vaccum system which sucks any unused fuel back into the tank..
when the fuel light comes on the 'reserve tank' is in use, so go fill up with some juice!
Nov 10, 2008 | 2007 Aprilia RS 125
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
