The dryer has heat but it takes forever to dry one load. I'm not sure what part to change?
SOURCE: Clothes dryer not getting hot enough to dry in a good time frame
i have a hotpiont TDC32 i have changed heating element and thermastacs and it still does not get as hot as it should it takes ages to even half dry has anyone got any ideas please i have cleaned all the filters etc...
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
SOURCE: My LG electric dryer DLE3777W takes forever to dry
Check to see if your vent is not kinked or clogged. Also, check if your lint screen is clean. If you don't clean it each time you loose 10% efficiency. Good Luck
SOURCE: LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
