Question about Daewoo DTQ-27U4SC 27" TV
I got a tv on ebay
I got my tv off ebay and its the american daewoo dtq-27u4sc 27
iv took the plug off too change it and it has a black wire and a white wire cud you tell me witch one is the live wire please
    President:
  • 1,489 Answers
Black is hot (or live).
Posted on May 11, 2009
What is the directv remote codes for daewoo dtq - 27u4sc
0382,0388,0380.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 29, 2014 | Daewoo DTQ-27U4SC 27" TV
A black box appears and dont know how to get rid of it.
the low channel no sound indicates the tuner is failing. A black bar on top shows your electrolytic capacitors are failing and you are about to lose your vertical output transistor, then the voltage rectifier
Nov 28, 2013 | Daewoo DTQ-27U4SC 27" TV
Use factory reset on a daewoo TV
You might have to enter its service mode to do this. If you wish to get more details about how to enter service mode to Daewoo TVs, check this site. Pull up older posts there.
Mar 24, 2013 | Daewoo DTQ-27U4SC 27" TV
Daewoo tv remote codes
0130 0004 0009 0100
................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
Aug 31, 2012 | Daewoo DTQ-27U4SC 27" TV
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
Lost original remote. need to find replacement.tried programing direct t.v.remote,but it wouldnt accept any of the codes given. I tried manually according to directions, but after hundreds of clicks it...
If you can't get the direct tv to work with your television universally you may need to purchase a remote that will control this television.
http://www.replacementremotes.com/store/prodthumbs.cfm?ns=1&keyword=dtq27u4sc&category=
Mar 03, 2011 | Daewoo DTQ-27U4SC 27" TV
What is remote code of daewoo tv?
You can try these codes from daewoo. 0019, 0039, 0092, 0451, 0623, 0624, .thanks
Jan 14, 2011 | Daewoo DTQ-27U4SC 27" TV
IS THIS A DIGITAL TV
No,all tvs have a CRTS(tv tubes) are analog tvs.
Oct 17, 2010 | Daewoo DTQ-27U4SC 27" TV
Black vertical line on screen periodically- but most of the time
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 20, 2010 | Daewoo DTQ-27U4SC 27" TV
Daewoo DTQ-27U4SC Display Problem
Sounds like your closed caption may be on and here is how to turn it off..
1. Press the menu button until you get to the "SPECIAL" menu.
2. Make sure that Closed Caption and CC on mute are both set to OFF.
This should make that black box go away...
Good Luck and please rate this solution...
Jan 06, 2010 | Daewoo DTQ-27U4SC 27" TV
Daewoo DTQ-27U4SC 27" TV Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
