I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Hook up one positive wire to the right side output of your amp, do the same with the negative wire for that speaker, right side out put. Then repeat the same for the other speaker, but on the left channel.
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
