Question about HP Pavilion dv9000z Notebook
I have an HP Pavilion DV9000 15". I tried using the Mic yesterday and it wouldn't work. It worked a few months ago. The person on the other end could hear when i hit the delete button but couldn't hear me. I've checked and nothing is muted, the volume is up. Help. Please.
I turned on my hp Pavilion Notebook yesterday
Try and get into safe mode; F8 just before boot. If you can select a restore point dated before the problem and let it restore.
Oct 09, 2014 | Computers & Internet
A few months ago, the bulb wouldn't come on, so I
When you say 'bulb' ... I assume you mean the sewing light ? The Artista 180 does not have a conventional 'bulb' for the sewing light, but a fluorescent tube that's a 'C' shap and surrounds the bottom of the head unit by the needle. This is driven by a high-voltage converter that runs off a supply on the main processor board. If the machine is working normally but there's some intermittent on/off of the fluorescent light, it could be simply that the tube's had-it, in which case its off to the service man for a new one - it comes as a complete tube and converter replacement. But before you do that. TURN THE MACHINE OFF. unscrew the hex socket that holds the head cover on and remove the head cover (the cover over the needle end). If you look at the head mechanism, looking towards the foot pressure control (i.e. the 'end' of the sewing arm) you should see a small cirucit-board just above the fluorescent tube with a fairly large 2-pin connector on the top - this slides on to the circuit board. Try giving that a careful wiggle to re-seat the connections, but PLEASE BE AWARE THAT THIS IS A HIGH-VOLTAGE PART AND THEREFORE DANGEROUS, so you MUST NOT touch it with the machine switched-on. Hope that helps.
Sep 07, 2011 | Bernina Artista 180
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
May 30, 2011 | HP Pavilion DV2910US Laptop
How do you fix DV6000 backlight not switching on?
It is unlikely an issue with the backlight. The HP Pavilion dv6000 line had an overheating issue which caused issues with the motherboard, often resulting in the video card and/or monitor not working.
HP offered an extended warranty on the affected models, but it ended a few months ago. Please see this page for more information:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01087277&product=1842155
If Step 2 of this page aptly describes your problem, it can only be repaired by replacing the motherboard. Apologies.
May 24, 2010 | HP Pavilion dv6000 Motherboard
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
HP Pavilion md5880n TV new lamp, left red light
I had the same problem the bulb was good but no power it was the transformer 975.00 under warranty from brandsmart. It worked for 90 days then the mother board went bad it cost 1000.00 they won't fix it .they gave me 1098.88 for a new one .Im gonig to sell mine for parts . I also have the stand for my tv also .
Jul 11, 2009 | HP Pavilion MD5020N 50" DLP HDTV
Microphone just stopps working out of the blue
try this on both computers:
first solution:
go to start
control pannel
sounds and audio devices
click on audio
make sure that a mic is selected.
second solution:
double click on the small spkr icon at the end of ur taskbar
make sure ur mic channel is enabled
Nov 15, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv9000z Notebook Logo
226 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
