Sounds like you may have water in your gasoline. Look in your gas tank on the mower with a flashlight or a pen light and see if there are bubble like globs at the bottom. Do the same with you gas can. The best thing would be to get out the bad gas in the tank and put fresh gas in if that is the case. The other thing you could do if you find you have water in it is to go dawn to the Auto or hardware store and buy a can of Heet or any other type of water remover. Try and run it and refill with fresh gasoline.
If the gas is good try and see if the spark plug cap is tight or even just take the plug out and give it a good look. Another thing it could be is if your getting air in the gas line from a crack or if it is loose.
diagram to put a belt on. Ariens s 16 lawn mower hydrostatic snow thrower. How does the belt go on...
(More)
diagram to put a belt on. Ariens s 16 lawn mower hydrostatic snow thrower. How does the belt go on to connect the snow thrower?
My 22" Front Wheel Drive Toro lawnmower won't start. It has less than 10 hours of use but...
(More)
My 22" Front Wheel Drive Toro lawnmower won't start. It has less than 10 hours of use but hasn't been started in over 2.5 years. I suspect the carburetor needs cleaning. Where can I get that done and what would be an appropriate price? I live on the West side of town in Las Vegas, Nevada (89138).
I am trying to hook up a pass & seymour 3 way switch & pilot light to red,...
(More)
I am trying to hook up a pass & seymour 3 way switch & pilot light to red, white and black wires with ground. Need a picture wiring diagram showing how to hook this switch up. Can you help me please !
