Changing color cartridge on my epson stylus color 980 printer.
I have an Epson stylus color 980printer which is several years old. It has worked very well until I wen t to add new print cartridges. When I opened the black cartridge , the old cartridge poped right up as described in yhe manual. When I shifted to the color cartridge, however, when I lifted the ink cartridge clamp the cartridge remained locked in place.How can I get the old cartridge out? I would Appreciate any help you can give me.
    Scholar:
  • 94 Answers
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Posted on May 11, 2009
Tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
on Sep 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Tip
Reset Epson Color Printer Counter
Many Epson Printers that reach an End of Life counter number will lock your printer down and force you to contact a Service Center.
However, this is really not necessary in all cases. If your printer is still working fine for you but the counter has locked your printer:
To download this free utility program read the agreement and then download.
Follow all instructions for download, install and usage.
End user agreement
1) This software is provided "as is" without any express or implied warranty of any kind including, without
limitation, warranties of merchantability, non-infringement or fitness for any particular purpose.
2) You are liable for all risks in relation to the quality or performance of this software. In no event shall SSC Localization Group or personally, author of this software, be liable for any damages whatsoever caused to you or the third party arising out of the use or inability to use this software. Damages include general damages, special damages, accidental damages or consequential damages (including, without limitation, loss of data or accuracy or unfitting interface for other programs, or problems with peripheral equipment).
2) You understand the risk of whole head or individual nozzles clogging in case of tardy replacing of empty cartridges, as well as risk of using hot swapping function (this include frequently cartridges replacement, or wrong deblocking of parking head on some models). You understand, that resetting the ink level counters or using ink freezer function implies responsibility to carefully watch ink levels in all cartridges and timely (as soon as You see any raw white bands, even in one color) replace cartridge.
I agree with all above statements and want to download software (v4.30)
Supported Models:
Model
Epson Stylus C50
Epson Stylus C60
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson PictureMate
Epson Stylus Photo
on Aug 31, 2008 | Laser 3115cn All-In-One Printer
Changing the ink cartridges?
I have an epson (2 of them). I have to raise the lid and then hold in on the color button for about 6 seconds. Yours should work similar to mine.
Jul 23, 2010 | Epson Stylus CX7800 All-In-One InkJet...
I would like to refill Epson Stylus CX9400 old ink
I wouldn't recommend it because it will void your Epson warranty.
Color Ink prints are nice, but this cannot be an everyday printer --- the cartridges will put you in the poor house.
Buy a cheap monochrome laser printer (recommend the Brother brand) and save the purple ink for the elections.
Cheers!
Mar 19, 2010 | Epson Stylus CX9400 Photo Printer
No ink output from Epson Stylus Color 777
I don't have an answer for you but I have the exact same problem.
I have an Epson Stylus Color 777 and I put in new cartridges (black and color) that I bought yesterday (03/05/10).
I pulled the tape off the cartridges and inserted them in their carriages. Everything works like usual except that no ink at all prints on the page. Comes out completely blank.
Nov 11, 2009 | Epson Stylus Color 777 InkJet Printer
Problem with colour printing. Orange and green
Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't work because of the clogged permanent printing head. The authorized service center is unable to repair it because the spares are no longer supplied.
Throw it to a recycling center.
Nov 03, 2009 | Epson Stylus Color 740 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Several colors not working after replacing cartridges
ur clour cardige has been damaged or jammed
so u have to do this buy the new cardige & replace it
Mar 31, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX6400
Blank pages are indicative ofdried ink.
If the printer has not been used for a long time ink may have settled and dried in the heads.
You may need to replace the cartridges (IF they are very old) and run several head cleanings if there is no improvement.
I typicall try to print a few test pages to see if some of the color work.
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Nov 11, 2007 | Epson Stylus CX6400 All-In-One InkJet...
265 people viewed this question
k24674
jasbo
jasbo
