Question about Car Audio & Video
Speedometer - slow/sluggish to register speed
Hi, I have a 1995 Toyota MR2 (not an import). I have recently replaced my original car audio system with a Sony audio system and had a new ariel fitted. The work was done in stages with the audio work done first (with no apparent effect on the rest of the car). However, when the car electrician replaced the ariel it initially blew the fuse on the speedometer. Apparently Toyota had the ariel wired through the ECU car computor. He then wired the ariel through the car ignitian. As a result everything works apart from I am left with a sluggish speedometer, which reads correctly - but it takes too long to register! At speeds over 50 mph (3rd gear and around 6.000 rpm usually means I am doing speed approx 70 mph -the speedo now is only just climbing over 50mph). It is booked in to be looked at obviously, but I would appreciate any advice for the electrician who has worked on MR2 's before and never had this problem!! I am concerned that the ECU could be damaged in the process of all this replacing of parts.
  • 78 Answers
In situations like that, the quickest way to diagnose that problem is to install a "good" speedo and see what happens. If it works fine, problem solved, if not, ECU or wiring.
Posted on Jul 07, 2009
Toyota MR2 spyder engine failure
when an engine overheats that bad , the cost to rebuild is generally close to a fully reconditioned exchange engine
check the wreckers / junk yards for a good engine of the same family group as is on the compliance plate /build plate on your car ( many such places import engines with low miles/klm that are in top condition
the rebuild will include new head or head rework , new pistons and rings , bearings , engine re-bore and all of that will not include the labour charges
burning a motor is not an inexpensive experience and that is why I suggest a second hand motor or a service exchange motor for an accredited engine reconditioning shop
Jul 16, 2017 | 2005 Toyota MR2 Spyder
It seems a bad idea , Just doing a good repair is like new :
replace head valves seals
replace head gasket , also check head plain
check cylinders for wear
repalce piston rings
Jul 07, 2017 | 2005 Toyota MR2 Spyder
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
1995 MR2 without any power. Brand new battery. No radio, wipers, and will not start. Turn the ignitiion on and headlights and emergency flashers are the only thing that works.
You need to check all the main and other fuses, also check the wiring to battery postive terminal. this sounds like a fuse or fusible link has burned out.
Oct 27, 2010 | 1995 Toyota MR2
I need to change my rear disc pads on a 96 MR2, I have removed the old pads but are unable to the retract piston to fit new inner pad. What do I need to do?
ask a mate to undo the bleed nipple while you lever out the piston,let them undo it after you apply pressure so that you dont get air in system.
May 02, 2010 | 1995 Toyota MR2
CENTRAL REMOTE LOCKING
Sir,
In every remote there is a cell to give it a power . it seem to me that the cell of your remote have completed its age. you are suggested to replace the cell of remote with new one. Hope fully your problem will be solved.
Aug 30, 2009 | 1995 Toyota MR2
1990 mr2 tbar import front damper removal
They are known for dampers going bad. replace.
Mar 29, 2009 | 1991 Toyota MR2
Swaying mr2
You need new spherical bearings.
Contact www.twosrus.com for more information.
tell him johnnyrocket sent you
Mar 18, 2009 | 1995 Toyota MR2
Toyota mr2 1995
haven't heard of such a thing as yet. Have you tried blocking the vent from underneath
May 23, 2008 | 1995 Toyota MR2
Car Audio & Video Logo
209 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
