Question about Briggs & Stratton Power Products 1539 Pressure Washer
Have a generac 200 psi power washer and when i get it all hooked up its ready to go but water does not come out of the nozzle but pushes out other places. nothing stopping it up that i can see.
3 Suggested Answers
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
  • 1388 Answers
SOURCE: troy bilt pressure washer 2550
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
Posted on May 31, 2011
My powerwasher Generac model# 0060223 is spraying water I think from the pump. Any ideas as to what is wrong.
if you did not winterize it it might have froze up and busted I was given one years back that si what happened to it before I got it and luckily I was able to fix with some lock tight spread on a thin layer and clamped it tight for several days to cure out
Apr 17, 2015 | Generac 6022/5989 2700 PSI 2.3 GPM 196cc...
My new 2500 psi generac power washer will not start
is it getting fuel ? Do you know if it is getting a spark ?
Sep 14, 2013 | Generac Pressure Washer - 6020
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
When pressure washer engine is running and hooked to water supply, there is no water spray with trigger is depressed
Hi Have you checked that your nozzle in the lance end is not blocked. Please try this and then try without the high pressure hose attached.
Oct 27, 2009 | Karcher 2500 PSI Pressure Washer
New nozzle, plenty of water, but no pressure.
It is warrantied for 1 or 2 years. Low pressure could be due to the un-loader valve needing grease. If it is leaking it will not work properly. If it is stored somewhere cold during winter months the small parts inside will crack.
Sep 18, 2009 | Karcher 2500 PSI Pressure Washer
GENERAC POWER WASHER PUMP
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
Sep 10, 2009 | Plumbing
MY HONDA POWER WASHER
Nozzle is dirty. Use small diameter wire to clean out nozzle.
Sep 09, 2009 | Honda Pressure Washer PSI 3000
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Briggs & Stratton Power Products 1539 Pressure Washer  Logo
171 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
