Question about GE GSS25SGMBS Side by Side Refrigerator
Hotpoint fridge model CSx20KATA AD defrost timer
I have a hotpoint fridge model CSx20KATA AD and it won't defrost. I can't seem to locate the defrost timer and was wondering if another part could be the root of the problem as well.
  • red_scorp411 May 11, 2009
    Actually it does have one, I found the defrost timer behind the control panel. I see your point that the problem may be from the defrost heater or termination switch. How do I know which one is the problem, the timer or those two parts?
    Is the defrost heater the big colied thing with the spikes under the frost that you're saying must have continuity? and is the termination switch the thermostat round metal thing stuck to it that has wires coming into it as well?
    Okayy I have figured out that there are three parts that could be the cause of this problem and I have found all 3: the defrost timer, the bimetal thermostat, and the defrost heater.
    Now I just need help figuring out which one is the root of the problem and needs to be changed?
    Is there anyway i can test each of these parts right now the way they're installed to see if they are functioning?
    like can i turn on the fridge and see if the defrost heater gets hot at some point in its cycle.
    President:
  • 1,136 Answers
Hi, This model does not have a defrost timer. It actually has a motherboard. If you have a defrost problem, the nore common part to check first is the defrost heater or termination switch ( bi-metal). These two parts are located inside the freezer compartment behind the rear panel where the frost is building up.
These two parts must have continuity. If one or noth of them have no continuity, they need replaced. Please use a hair dryer (NOT a sharp object the remove the frost from the evaporator coils.
If you need any more help or need to order the part, I can help you and we can order the parts off my web site WWW.Whirlpoolpartssurplus.com
Let me know if I can help.
Thanks
Vic
Posted on May 11, 2009
  • Victor
    Victor May 12, 2009
    Yes you can turn the defrost timer to the defrost cycle by turning the little button clockwise until you here a loud click. Plug the refrigerator back in and see if the heater glows. Make sur the freezer is still cold so that the bimetal is closed. If the heaters do not come on, you can check voltage where the wires go into the heater and you should get 120V. If you do not have voltage to the heater, you need to check the bimetal switch. best way to check that is to see if you have continuity. 75% of the time, the heaters is the problem.
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
Where is the defrost timer on model HSS25GFPAWW side by side fridge
on this model it is included on the main circuit board # 8010fe6e279-086d-4a6a-8771-05f57d99721e.gif
Mar 22, 2014 | Hotpoint HSS25GFP Side by Side...
Schematics for Hot Point refrigerator model #HTR15ABMFLWW TOP FREEZER
Your defrost thermostat might be bad or your defrost timer. Look those parts up using your model number, if you need help locating these parts in your fridge let me know and I can show you how to do it. hope this helps.
Mar 05, 2013 | Hotpoint Refrigerators
THe draws in my fridge freezer can no longer fit in the compartment and the door close. The back panel in the freezer apperas to have moved forward
Perhaps you have an ice buildup causing this remove the rear cover inside the freezer.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Aug 30, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
The fridge is freezing all food contents even when on factory setting 6. How do I resolve this?
It's common problem. You have to check Defrost timer, thermostat and defrost heater. Any one malfunction, you will get over frosting. How to check?
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 02, 2011 | Hotpoint FFA90 Bottom Freezer Refrigerator
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Myfreezer works fine but my fridge only works for about 15 days and then stops working,when i unplug the fridge and let it defrost the freezer will work for another 15 days it is a hotpoint ff4dx fridge...
This is telling you that you have an automatic defrost problem.
Before I go on here the model number you passed appears to be a UK model.
The problem can be:
1. The defrost timer / control
2. The 60 deg F defrost bi-metal thermostat
3. Wiring
4. The defrost element.
Some info about the 5 year warranty is on page 11 of the owners manual: http://www.hotpoint.co.uk/hotpoint/_pdf/manuals/19506810502_UK.pdf
I do not locate the appliance parts manual for this unit as I am not in the UK.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Refrigerators
Fridge Icing Up
Sounds like you have a defrost Prob. Take back cover off. Turn defrost timer in to defrost mode you will feel a click. timer may be located in fridge. ceiling or back wall if not there check bottom of fridge. behind kick plate or in back bottom of fridge. by compressor. See if heating element gets hot if not check for 120 volts at heater and defrost thermostat ( Terminator ) if not check defrost timer if you do have 120 volts check for 120 volts at heater terminals if no voltage or weak voltage replace terminator if you do have good voltage replace heating element. When ice builds up the fridge. starts to get warm turn off for 24hrs turn back on fridge. will run OK till ice builds back up.
May 22, 2010 | Refrigerators
The freezer warning light keeps coming on, nothing seems wrong with the fridge but every day the freezer high temperature light comes on
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Feb 18, 2010 | Hotpoint FFS70 Bottom Freezer Refrigerator
Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Jun 16, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
179 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
