Question about HP LaserJet 3330 All-In-One Printer
HP laserjet 3330 Permanent Storage Init.
How do I get my HP laserjet 3330 to actually start up and get past the "Permanent Storage Init"? I would like to get this thing fixed ASAP, so if any one has any advise please let me know.
    Novelist:
  • 102 Answers
Switch of the printer press and hold down menu and cancel button turn on the printer keep holding these two buttons and turn on the printer.
As soon as printer display shows permanent storage init. release both the button.
Posted on Jul 04, 2009
SOURCE: HP laserjet 3330 MFP
It will eventually reset itself, usually after being unplugged for an hour or so, but the error will return regularly. There are several posts all over the place on this error, but it seems that it is seldom solved, without replacing the scanner unit (entire top of machine) - which is obviously not worth the hassle/expense. Just seems to be a common problem with this family of machines
Posted on May 17, 2009
SOURCE: laserjet 3330 firmware upgrade problem
Sorry, but these models are infamous for the "Scanner error". Firmware, seldom, if ever solves this problem. Temporary solution is to turn machine off/on, wait for scanner to "walk out" (move to the left), turn off/on again, wait for it to move again. Do this three to 4 times and then let it complete it's warm up. The error will return frequently, this is just a workaround.
I'm a fan of HP, but this family of machines had major issues.
Hope this helps a bit :)
Posted on Apr 26, 2009
SOURCE: my hp laserjet P4014n is
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Posted on Oct 26, 2009
shishirgarde
  • 114 Answers
SOURCE: HP Color LaserJet CP3525 68.X PERMANENT STORAGE
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
Posted on Nov 01, 2009
VKUR
  • 62 Answers
SOURCE: HP laserjet 3330 keeps flashing scanner error
Remove and replace the power cord from the unit.
Wait approximately for 35 seconds for the scanning assembly to "walk out"(move to ready position)and then quickly remove the plug again.
Repeat step 1 and 2,three or four times until the head (scanner lamps)moves approximately 1 inch away from its normal resting place.
Replace the plug and let the product fully finish the boot cycle.
If it does not resolve the issue or the issue returns,upgrade the product firmware may help.Visit this url http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=72628&lang=en&cc=us&prodTypeId=18972&prodSeriesId=66359&taskId=135
and then upgrade the firmware.
Posted on Feb 10, 2010
How to factory reset the hp pro 300 laserjet printer
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
Jul 14, 2016 | HP Office Equipment & Supplies
Why is there permanent storage init error?
web search HP laserjet printer error codes
Sep 15, 2015 | HP LaserJet M1005 Printer
How to cold reset in HP LaserJet 1536 dnf mfp
Resetting the HP LaserJet Pro M1536dnf accomplishes the following:
  • Clears all data from the printer's memory (including unprinted data, downloaded fonts, and macros).
  • Stops any printing that is taking place and ejects the page.
  • Removes some error conditions.
  • Resets the printer to its factory default settings.
Reset Procedure:
  • Turn off the printer
  • Press and hold the Left arrow & Cancel while you turn on the printer
  • Once you see Permanent Storage Init you can release the buttons.
  • The printer should now start resetting.
Thanks,
HP Printer Support
Jun 10, 2014 | HP LaserJet M4345 MultiFunction Printer
Reset factory settings
Turn printer 'OFF'.
Hold Cancel button and start/Copy button at the same time.
Turn printer 'ON'.
Release the buttons after display shows "Permanent Storage Init".
Wait till the display shows "Ready"
Jan 10, 2014 | HP LaserJet Pro M1212nf MFP -...
Memoy reset for HP LaserJet M1212nf MFP
Turnoff the printer.
Turn on the printer.
Release the buttons when display shows "Permanent Storage Init".
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
Sep 26, 2013 | HP LaserJet 2840 Printer
My hp laserjet 3330mfp reports a scanner bulb is warming up and it never goes off. I have tried to unplug then plug back in. The printer works fine.
Here is how to cold reset the machine. also I added some addtiona options below as well.
1 Unplug (or turn off) the product from the power source.
2 Press and hold down the * and menu/enter keys.
3 Continue to hold down the keys while you plug back in (or turn on) the product, through the entire power on sequence.
4 When the control panel display reads Permanent Storage Init. release the keys.
5 Allow the product to return to Ready before using the product.
If that doesn't work it can be a power related issue,
- Make sure it's NOT plugged in to a surge protector.-
- Try a different outlet on the wall.
if theses steps fail you will most likely have to replace the scanner assembly
Another Option you can try as well :
Also I found this on a HP forum NOT SURE IF IT ACTUALLY WILL WORK:
" Scanner Bulb Walkout - Unplug the power from the unit,plug the power back in wait until the unit reads "Scanner Bulb Warming Up" Unplug the unit. Repeat this step 5 times.
This should move the scanner assembly back to its home position.
link to this post : http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=989123
Oct 20, 2010 | HP LaserJet 3330 All-In-One Printer
Why does my HP laserJet M1522nf say private? how can i change the settings to auto?
Try an nvram. Hold the down arrow and the cancel button. Turn the printer back on and wait until permanent storage init is displayed.
Al
Aug 31, 2010 | HP LaserJet M1522nf Multifunction Printer...
Describe how to clear memory from HP LaserJet M1522nf
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
Jul 22, 2010 | HP LaserJet M1522nf Multifunction Printer...
Logic card reset for hp color laserjet 1312 nfi mfp
2. Press and hold the Right arrow and Cancel buttons simultaneously.
3. Turn on the printer.
4. When you see the message Permanent storage init, release the Right arrow and Cancel buttons.
Jun 28, 2010 | HP Laserjet CM 1312NFI Color Printer
HP LaserJet 3330 All-In-One Printer Logo
2,388 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
