Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 hp 42 in cut craftsmen lawn tractor.I got from grandmother,blades were bent got new sears blades still digs into ground and doesn't cut in middle,do I need a new deck?
  • bigdaddy2510 May 12, 2009
    thanks for the help.
    President:
  • 2,559 Answers
No,You need to park on a level area and lower the deck to it's lowest setting and adjust the deck with the large butterfly nuts on each side,just under the foot pan,just loosen and let the adjusters fall into place,Tighten back up and it should be set.You may need to do this more than once.
Posted on May 11, 2009
I have LT1000 42inch Craftsmen (green colored ones). Underneath the cutting deck, the blades connect to a "base" that spins. This spinning base goes through some sort of "metal piece"...
it is the bearing hub, they make several different ones you will need to remove it and take it with you to sears or rual king of one of the other farm stores so they can get you the right one.
Feb 17, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I would like to replace the mulching blades on my Sears Craftsman riding mower with regular cutting blades. I can find plenty of sources for new mulching blades, but not cutting blades. My mower is a model...
The straight blade for the 42 inch mower is 138971.They cut better and are easier to sharpen and you will need them if you use a gass catcher. If you do not want to use sears for parts you may be able to find good deals on ebay.
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Sears Tractor Mower 42" is cut cutting lawn in two uneven strips
First, check the blade, it may be bent. If not, there is an adjustment nut (9/16) on each side in the middle of the deck hanger bracket. Get on level surface and screw each up or down to get blade tips the same height on each side.
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftmen mower doesn't cut well on right side
Sounds like you may have made a common mistake, getting one or both of the blades upside down.
Jun 28, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mowing blades on 42 inch deck are not cutting evenly.
go to sears.com
find parts direct at the top click on it
a place will come up where you can enter you mod#
click on search aftermod # entered and everything part wise will come up for that tractor
on the left hand side
Jun 15, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
RIGHT SIDE BLADES CUTS LEVEL, LEFT SIDE DIGS INTO THE GROUND
the right side cuts level but left side doesn't well the answer i have would be that someone stepped on the deck which will cause the adjustment arms to bend & deck will not be level or the only other thing it could be is the blades could be bent as well if i can further help e-mail me @ wadembly@aol.com thanks ,wade
Jun 08, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
223 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
