Question about HP Designjet T1100 Photo Printer
HP Designjet T1100 media roller vibration
The problem is with a HP DJ T1100. With no rhyme or reason
the media advance roller will (while printing) stop advancing the
paper and just shake back and forth. You can sometimes get it
stop by forcing the roller by hand, otherwise you need to recycle
the plotter. I have changed the media advance drive, the encoder
sensor and encoder disk and the problem is still there.Any ideas
on whats causing the problem and how do I fix it. Thanks.
Bob B. Syracuse NY
SOURCE: HP design jet 450C inkjet Media Error`
The pen cassette slide bar (aluminum) is dirty. Wipe it clean. Lube it. I used a light coating of 3 in 1 oil. Push cassette to the left. Close cover. Turn machine off and on.
Posted on Jul 11, 2008
  • 141 Answers
SOURCE: PRINTER DO NOT ACCEPT PAPER ON HP DESIGNJET 450C
either the carriage board, line sensor, encoder strip, or electronics module are defective. The media sensor would not cause this behavior.
Posted on Sep 11, 2008
mickspaceNET
  • 115 Answers
SOURCE: HP LASERJET 4 PAPER JAM 13
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
http://www.all-laser.com/cgi-bin/webc.cgi/Menu_HP_maint.html
Posted on Oct 23, 2008
  • 33 Answers
SOURCE: 47.01 error
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-177.
�� If the System Error continues, replace the Main PCA
Posted on Nov 07, 2008
  • 53 Answers
SOURCE: cartridge path
By it going back and forth means all is ok with the encoder strip. Sounds like its asking for a bit of lubrication. There is a special oil available from HP for the carrage. This also works for tha large format machines using plastic bushes such as 500, 800, T610, new 510 etc.
Posted on Feb 06, 2009
Hp t1100 grinding noise after print
I suggest you run the diagnostics for the printer which allows you to isolate and run individual components. That way you can see which item is causing the noise. If it is coming from the left side, you might have a problem with the cutter.
Dec 17, 2016 | HP Designjet T1100 Photo Printer
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Print head
Update your firmware.
Apr 30, 2013 | HP Designjet T1100ps Printer
My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Feb 27, 2013 | HP Designjet T1100ps Printer
How to resolve eror code 47.01 hp designjet T1100
this error code is Starwheel Motor failure.
Feb 25, 2011 | HP Designjet T1100ps Printer
Hi ! can you tel me how to resolve eror code 47.1 for hp designjet t1100
I have this error with my Designjet T1110. I followed the instructions in the service manual 2-14 for troubleshooting.
questions:
- instructions say :"Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA." but I could not locate any cable from the starwheel assembly to the main PCA. I could see only cable from the starwheel motor assembly to the main PCA.
Feb 25, 2011 | HP Designjet T1100 Photo Printer
I am faceing the problem hp dj t1100 inkjet printer. No connectivity avaiable.
For a single computer you can install a JetDirect card and assign an IP address. Then connect the computer to the plotter directly through the ethernet connection on the computer using a cross-over cable (standard ethernet cable will not work unless you use a hub). Another option is to simply use a USB cable connection. Drivers are available from HP.com, Support, Downloads.
Mar 02, 2010 | HP Designjet T1100 Photo Printer
HP Designjet T1100 Photo Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
