Question about GE GSS25JFM Side by Side Refrigerator
Water leaking randomly under GE refrigerator - GE GSS25JFM Side by Side Refrigerator
  • jose castillo May 12, 2009
    Thanks. I'll Try that this weekend when i have more time.
    Sergeant:
    Champion:
  • 214 Answers
It sounds like you have a plugged drain tube.The easy way to clean it would be to unplug fridge over night with the doors opend to defrost then remove rear bottom panel.After that you should see a tube going into a drip pan clean the end and blown in to it with a air tool or if you wantt o fast clean the end and use your mouth.After line is clear you can pour hot water into freezwer part and see if it drains into **** pan hope i helped :)
Posted on May 11, 2009
Ge GSL25JFTA is leaking water on the floor from the front of the unit
Turn off the water supply to the ice maker. If it stops the leak, look for a leaky O ring on the filter. There is a plastic hose that runs out of the front of the refrigerator and goes to the freezer door for the water dispenser. It has a connector near the freezer door lower hinge so the door can be removed easily. That connector can leak as well. There is a condensate pan under the refrigerator that may be over flowing too.
Mar 21, 2015 | GE Refrigerators
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side is freezing up where the water comes out to fill ice tray and is also leaking water on floor.
Leaking under a refrigerator may be caused by a condensation tube that doesn't drain into a pan or by a clogged freezer drain.
Please check the bellow link to trouble shoot your problem regarding leaks and ice built up in your refrigerator:-
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side refrigerator water dispenser turn on.off at random - short 1-3 second bursts - no one near it. cause / solution?
change the water valve . / it could be a short in the main board or a touch pad that is tempt sentensive . but i would change the water balve i thing it's leaking through .. mm
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking under the refridgerator
SOUNDS LIKE THE EVAPORATOR FAN HAS STOPED WORKING
Aug 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
Refrigerator leak
check to see if the line is cracked under the water valve
May 02, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE GSS25JFM Side by Side Refrigerator Logo
163 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
