Question about 3M (EP7630AVR) Video Capture
PC Problem after installing Kingston PC3200 1G in my Asus P4PE-X
My computer started to hang whenever I open or run a program after I installed Kingston PC3200 1G in my Asus P4PE-X, I use before a 512 MB of PC333.  What could be the problem?  Thanks.
djromil
    Problem Solver:
  • 17 Answers
Although i agree with ardmax's solution. Another thing to bear in mind....... in my experience at least, Kingston memory has quite a few compatibility issues. In my job we use a wide range of HP PC's and laptops, some of them will happily use Kingston and some simply refuse to boot.
I have heard of other compatibility problems as well but I'm not 100% sure of which manufacturers have this problem and I don't want to start bad mouthing the innocent
Rule of thumb with memory, you get what you pay for (most of the time)
Posted on Mar 05, 2008
Change the morherboard
Posted on Jan 15, 2008
    Scholar:
  • 155 Answers
As you can see in the manual http://www.bcom.de/ftp/treiber/Asus/Hanb%FCcher/p4pe-x_e1303.pdf page 1-13 to use a memory PC3200 you must have a processor working at 800 MHz FSB, now you probably have a processor running at 533 MHz FSB.
Posted on Oct 19, 2007
  • Massimo Ardito
    Massimo Ardito Oct 24, 2007
    Can you explain why it was not helpfull, did you solve your problem?
    Thanks for let me know
No sound from ASUS D2X sound card
try updating the firmware and then look for a more up to date driver
Jan 07, 2014 | ASUS KGPE-D16 AMD Opteron Server Bd...
I have the NEC versa E6200. Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding. What should I do??
Have you run a Virus scan and a malware scan? when you say" Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding" whenever I use it means what just moving the cursor or going online, opening a program etc. could you be a bit more specific that would help in the diagnosis.
Oct 31, 2012 | Computers & Internet
I started up the Eee 701 netbook and it found 18 updates to the OS/software installed. I started to install them. During the process, the downloads/installs started to hang. So I restarted the pc and it...
Hi there.
You can try and resolve this problem by performing a system restore.
Click on the start menu/orb, select all programs, then accessories, then system tools and system restore.
Open the program and take the computer back to before it installed the updates.
If system restore is not in the menu, type rstrui in the search bar.
I also recommend you leave the computer to finish its update process because it can take some time to complete.
Please post back if anymore help is required.
Good luck
Jun 10, 2009 | ASUS Eee PC 701SD 8G Notebook
My motherboard won't startup or booth after reset & some installs
try to update your date and time from your BIOS. and check the battery if charging. if not change and replace.
May 06, 2009 | ASUS P4PE-X Motherboard
Help
Hi clcik on this link to download the drivers .
1)Click on the link below .
2)Click +AUDIO .
3)According to yourr windows version(like 98,ME VISTA,XP) , you can select the location(download from)and download will start.
4)Once the download is completed you might need WINZIP to open it, if it's already there on your computer ,you will see the setup file ,double click to install .
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4PE-X
Cheers
Jun 05, 2008 | Edirol UA-4FX External Sound System
Drivers for using with vista
http://support.asus.com/download/download.aspx?modelname=P4PE-X&SLanguage=en-us
Asus motherboard, no vista drivers for components listed, however I bet a new installation of Vista would detect proper driver installation
Feb 27, 2008 | ASUS P4PE-X Motherboard
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
2 gigs of ram
Re-check your manual at pg. 1-12. 1.9.1 Memory Configurations.
Since you know one bank of memory works fine in a certain slot. Now try the other in the same slot.
Jan 15, 2008 | ASUS P4PE-X Motherboard
P4PE Motherboard system hangs on 2 memory banks
you need to check in your bios settings for the amt of physical memory setting. alsoexamin the board for defect. if all that is good then follow the following instructions
1.)Unplug computer
2.)remove memory
3.)switch jp1 to clear ( the jumpewr that clears the bios is called jp1 its located close to the battery and it has 3 pins and 1 jmper) the pin set will be on 1 and 2 , simply set it to 2 and 3)
4.) Hit the power button 5 times to clear all remains of eletricity
5.) REPLACE JUMPER TO 1 AND 2
6.) replace memory
7.) boot up system
8.) on the main boot screel it should say no bios settings enter setup
9.) enter setup and load optimal defaults
10.) save and exit
Dec 31, 2007 | ASUS P4PE-X Motherboard
3M (EP7630AVR) Video Capture Logo
238 people viewed this question
Top 3M Televison & Video Experts
Are you a 3M Televison and Video Expert? Answer questions, earn points and help others
