Question about BroilKing Grilling
Superb Grill - changing burners.
Good afternoon.
I was wondering if you had instructions on how change the burners for my Superb Grill by Broilmaster..3 of the 4 burners have burned through.
The model # is SBG250-1.
Thanks,
Rob
    Problem Solver:
  • 7 Answers
Http://www.broilmaster.com/BROILMASTER/pdf/Owners_Manual_Superb_by_Broilmaster.pdf
Posted on May 12, 2009
How do I change the burners on a fd27lkec grill?
Good Afternoon Friend,
I understand you are trying to change the burners on your Frigidaire grill, model# FD27LKEC. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to change the burners with ease. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FD27LKEC (LP) Grill
Can I get instructions on changing the main burner
Good Afternoon David,
I understand that you are looking for instructions on how to change the main burner on your Electrolux grill, model# E44LB60ESS. This is typically not a do it yourself repair. I do recommend contacting your local authorized technician for repair as they would be more familiar with your grill. I hope this is helpful.
-Best Regards-
May 09, 2014 | Electrolux E44LB60ESS
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Is this yellow flame on my grill ok?
Clean out burner holes on all the burners they look blocked , then adjust air mix to burners could need more air to burn
Jul 23, 2012 | KitchenAid KBGS364PSS Grill
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
How do u change the burner in model 750-000408
Unfortunately, the Model Number you listed does not match any Napoleon Gas Grills. However, here are 2 links to instructions on how to remove the burners. These instructions cover 4 different models. Hopefully one of which will be similar to your model grill.
http://www.napoleongrills.com/Care/Burner_removal_P600.PDF
http://www.napoleongrills.com/Care/Burner_removal-308-450.PDF
I hope this helps you, Robert. Thanks for choosing FixYa.
Jul 27, 2011 | Napoleon Gas Grill
Good Afternoon..On my Tuscany grill only 1 of the 3 burners work. looking from left to right, the left one does not work at all and the middle burner barely. No smell of gas on the 1st and very little in...
Sounds like the offending burners need to be removed, checked thoroughly for clogs and particularly the venturi valve on each burner. And while you have them out, remove the burner orifice of each burner and look for clogs.
Hope this helps you to further troubleshoot and solve the problem. Happy Grilling!!
Apr 19, 2011 | Altima Technologies AGR48PF Grill
Have a 15 year old Weber Genesis. Recently filled the tank, and was working fine. Today, went to fire it up and barely any flame coming out of the burners. In fact, when I turn on the middle burner, the...
You need to completely change the grill because it's been there for over 15years and alot of rust and linkages will after affected the grill from working properly well.The best bet is to get a new grill.
Nov 25, 2010 | Weber Genesis Silver B Grill
Inadequate flame and heat
I'd change the regulator, clean the burners and the surrounding area. Make sure that the air intakes around the burners aren't blocked , plugged..
Also check the gas orifices for cleanliness... outdoor grilles are nutorious for bug hotels... these little critters move in, lay eggs and it can screw up the burners, orifices... I've several times needed to remove orifices to clean the inside of mini spider nests... Look them over closely..
Jun 01, 2010 | Weber Genesis Silver B Grill
Grilling Logo
261 people viewed this question
Top BroilKing Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a BroilKing Grilling Expert? Answer questions, earn points and help others
