Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg tromm wm2277wh washing machine
My machine is about 9 months old.  all of a sudden it wont fill.  the water goes into machines soap dispenser but very littel goes thru into the drum holding the clothes.  I can also open the bottom and empty all the water i just cant get enought to wash.  any ideas
  • Anonymous Oct 26, 2008
    mine is a WM2455HW, 10 months old, and all of a sudden there isn't enough water to wash the clothes. I hear the water going into the detergent tray, but don't see it coming out. I cleaned the inlet filters like the manual said, but still no difference.
  • 100 Answers
Is the water valve screens plugged restricting the amount of water going into the washer other wise your pressure switch is reading the wrong water level.
Posted on Oct 31, 2007
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
I have a front loading washing machine. The soap dispenser is no longer dispensing detergent into the machine
SOMWE TIMES THE TUBE LINES CAN GET BLOCKED OR CLOGGED OR EVEN HAVE LEAKS, YOU WILL HAVE TO TAKE OUT THE DISPENSER AND CHECK CONNECTING TUBES. ALSO TRY POURING VINEGAR INTO TUBE AND LET SIT FOR AN HOUR OR SO
Jan 27, 2016 | LG WM2688HWM TROMM SteamWasher
Water remaining in detergent dispenser on LG Tromm front load washer?
The water usually drains from the drawers just by gravity. Have you checked that your machine is level?
Nov 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
My lg tromm front load washer smells
Try this, It's involved but it worked on my Kenmore HE4tDrain the machinePull the filter (have a sheet pan, wet vac and towels handy, there's a lot of water)Disconnect the drain boot from the pump and tubDisconnect the pump drain hose (waste)Disconnect the pump electricalWash everything (not pump motor) in a 25% bleach solutionReassemble.Put 1 gal boiling water, 1 gal hot water and 1/2 cup bleach in washer compartment. check for leaksWash entire compartment with the bleach water and spin the drum time to time for 15 minutesAdd TechnoFresh (which claims to loosen gunk) to the powdered soap dispenser, through a bunch of rag towels in and run the machine on the hottest cycle.This process works well until machine is stinky again (about 6 months depending on bleach usage)BTW "the leave door open trick" only helps the door gasket and does not address the constant reservoir of fermenting water in the bottom of the machine
Feb 11, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The soap dispenser drawer is leaking water down the side of the machine.
try turning water pressure down a little, also pull drawer out 10 millimeters or 1 centimeter that might help. please reply if u need more help
Mar 22, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Washing Machines Logo
252 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
