Where is the low/high port for the AC to recharge the system
I need to add 134a to the system but can not locate the ports. I located a "D" and "S" which one do i hook up the 134 to.
  • rmullinsjr May 27, 2009
    Another mechanic told me reverse of your information and the system charge, will there be a issue with my compressor now?
  • 3 Answers
The D is going to be your discharge side which is your high side and the S is going to be your suction side which will be your low side... only charge on low side
Posted on May 27, 2009
How to recharge ac
There are many ways to recharge an ac system but to do it correctly is a bit more in-depth. You can read the ac tag under the hood of your vehicle and purchase a can of coolant then hook it up to the low pressure side as shown on the can. Start the engine and follow their instructions. If you have a leak you should add UV dye to the system to locate the leak then repair as needed. To recharge system I recommend purging the system to a proper catchment contaner, recycle the refrigerant as required. Put an ac manifold on the high and low ports of the ac system (they are sized to only fit in the proper location) then attach a moisture removing vacuum pump create a vacuum in the system of 20lbs at sea level or more. Close the high and low pressure valves and disconnect the vacuum pump connect the refrigerant to the vacuum line, start the vehicle, turn on the ac (fan on low) add the amount of refrigerant that your vehicle tag requires.
Jul 03, 2014 | 1999 Ford Expedition
Location of ac low pressure port location 2004 chevorlet avalanch
Look back on the firewall for the two a/c lines. One is large and on is much smaller. The larger line is the low pressure line. Follow that line back to the compressor. The low pressure port will be on that line.
Sep 01, 2012 | 2004 Chevrolet Avalanche
Cannot locate valve to add 134a refrigerant in a 2000 lincoln navigator
What your looking for is called a service port. On a 134a system there are two of them, located in the refrigerant lines. One port will be larger diameter than the other. The large one is the "high" side and the small one is the "low" side. refrigerent is added to the low side with the system running. You really should use a manifold gauge set to see what the pressures are before adding any refrigerant. If the system has too much, it is as bad as not enough.
Apr 26, 2011 | Lincoln Navigator Cars & Trucks
Where do i put the R-134a in on a 2002 volvo s60
On the low pressure valve located between the compressor and accumulator. The low pressure port has a black or blue cap covering the recharge valve. Don't worry, you can't connect the hose to any other valve port but the low side, the hose end is different from the high side. The high side has a red cap, and is not a recharge port.
Aug 22, 2010 | 2002 Volvo S60
How to recharge a 2005 volvo s40 with r-134a
hook up an ac machine to the low side port only which is located behind the passenger side headlamp in the engine bay. evacuate the system then vacuum it for 15 min then recharge it with the specified amount of refridgerant. there should be a yellow sticker in the engine compartment telling you how much to add
Nov 19, 2009 | 2005 Volvo S40
Locating the High side and Low side AC gas ports
Easy. find the compressor. The larger hose attaching to the compressor is the "suction" side. This is where you install the refrigerant.
The smaller hose, whether rubber or metal as it travels to the passenger compartment, is the high pressure side.
After installing refrigerant and as the compressor is running, the larger hose will feel cool and the pressure side will feel hot.
Jul 29, 2009 | 1998 Dodge Caravan
I need to retrofit and recharge my 1988 Dodge Ram Ac.
First, the old R-12 must be completely evacuated fromt the system. R-12 and R-134A do not mix and won't function together. Once you are sure there's no R-12 left in the system, you need to install an R-134A fill valve on the low side AC line. This is where your refill hose will connect to add R-134A. Once the valve is in place you're ready to fill the system. The compressor requires a minimum of 20psi to engage and should not be filled to more than 45psi.
RECHARGING AC SYSTEM
1.Turn the truck on and turn AC on HIGH
2.Locate the low side AC line (will have a valve and cap similar to the cap on a tire)
3.Insert the oil or R-134A can to the hose (Do not turn the screw to puncture the can yet)
4.Insert the other end of the refill hose to the low side valve
5.Puncture the R-134A can with the screw on the refill hose
6.You should feel the system suction the refrigerant out of the can
7.Check for frost on the AC lines and the air blowing inside the truck
8.If frost develops and the air is cold, you've successfully recharged the system and disconnect the refill hose. DO NOT ADD MORE REFRIGERANT...overcharging the system will damage your compressor and will be less effective
Hopefully this answers your question and you're able to get your AC working again. Best of luck.
Jul 21, 2009 | Dodge Ram 150 Cars & Trucks
My recharging kit for air conditioner doesn't seem to fit recharge valve on 2004 dodge durango. How can I be sure i am looking at the low prerssure valve?
Newer vehicle come with R134 vs R12. Since the two are not compatible, R134 has larger fittings. AC system has two ports, High and Low. Low is return to AC Compressor and high is output. High port is first following line from compressor to condenser (condenser is at front of vehicle like a second radiator). Keep following line till you find high port (paint cap red). Second port is low (paint cap blue).
Jul 11, 2009 | 2004 Dodge Durango
Recharge Auto air conditioner
I just did this for my 1994 Camry. Does your camry use the R-134A modern refrigerant? Probably.
Go to an auto parts store and buy a can of R-134A with a pressure guage included. You'll need that guage so you don't overfill the system. I bought one that allows me to save the guage and buy cheaper refills int he future.
There are two AC valves. A small one, located in the left-rear of the engine compartment, behind the strut tower, just in front of where the passenger seat is located. It might have a cap on it marked "L". This is the "Low" port, and is the one you want. The larger "H" port is up near the battery, is bigger, and is the "high" port. You don't want to use that one, and besides, it won't fit the can anyway.
Locate that low valve in the left-rear of the compartment. Take the cap off (if one is still on there). Start the engine and get it up to running temp. Turn on your AC to maximum cool, fan at maximum. Follow the directions on the can. It's pretty simple.
You'll pull back on the bushing on the refill line, and then snap it onto the valve just like you'd find on an air hose. Snap it into place, and then start refilling. Make sure the can is upside down and that you rotate and shake the can to get the coolant out effectively.
Jul 03, 2009 | 1996 Toyota Camry
How do I add coolant to the air conditioning system of my 2001 Hyundai Elantra?
You need to locate the low port on the AC.
You recharge the AC connecting to the low port.
You find the AC low pressure at the top of the compressor. Near the compressor you find two ports, the high port and low port.
You can follow the compressor line to reach the port.
To find out which one is the low port, run the air conditioner for a couple of minutes withthe engine on.
Then turn off the care and touch the lines from compressor to the two ports , often covered with plastic caps. Only one of the pipes will be cold, the line that is cold will lead you to the low port.
Jun 18, 2009 | 2001 Hyundai Elantra
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
