Question about Garden
Wont stay started
Put in fresh gas new air filter and it has plenty of oil
slohry
  • 87 Answers
SOURCE: redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Posted on Apr 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: CS30 Ryobi trimmer dies when I press throttle!
Yes. You just need to do a simple carburetor cleaning. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is in carb. is free of debris. Use a Den Tek Brush,(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb.
If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: 4 cycle engine wont stay running when pulling it has fresh gas
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
Jim
Posted on Jun 12, 2009
bbreton
  • 437 Answers
SOURCE: wont stay running, replaced spark plug and air
Try mixing fresh gas mixture, any fuel over 30 days old is gone bad, this may help. Or the carburetor may need rebuilding, or the exhaust screen on the muffler is clogged up. Remember before taking anything apart use either PB blaster or Deep Creep on the bolts before loosening them.
Brian
Posted on Sep 24, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a gas trimmer. It starts but will not stay
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Idles ok revs up and stalls out
Aug 13, 2013 | Poulan Garden
Wont start
If the same fuel is in it try draining and re filling with fresh fuel, if no better to rule out an ignition issue, spray some fuel oil mix straight down the carb throat, if it fires up it is still a fuel issue.
Jun 16, 2012 | Craftsman 25cc Gas Line Trimmer
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Cant get truck to stay running
did you try the fuel filter
May 20, 2009 | 2000 GMC Sierra
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
