Question about Rainbow E series Canister Wet/Dry Vacuum
Will not turn on
It wont turn on. the power went out at my house it flickered for several minutes and now the vacuum will not turn on. I tried different pluggs in the house and still nothing.
    Problem Solver:
  • 11 Answers
Leave it unplugged for a half hour then try it. But it sounds like it may have received a power surge or several. This could have fried the motor. The motor may have to be replaced.
Posted on Aug 14, 2009
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
My dyson will not turn on? I was using it and it just turned off, and wont come backon
Check the house fuse, use a different outlet, might be defective, check for fuse in unit.
Mar 31, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I recently purchased a Sunbeam Artista EM5900 model coffee machine. I plugged it in and pressed the 'Power' button only to find the power go out. I understand this is short circuiting, so I went and turned...
Try it in a different part of the house. If it works then you have too many things running in the kitchen. If it still blows a breaker then it is shorted out and needs to be returned.
Jan 08, 2011 | Vacuums
I was vacuuming with bissell 3750-T and I shut it off and went to turn it back on and will not start or do anything, what is wrong?
If you can't smell burning then it's probably a broken power switch or the vacuum got too hot and the thermal overload protection has tripped. Try leaving it off for 15-30 minutes and try it again. The thermal overload will reset itself during this time and it should work again.
In the meantime, make sure you have power to the vacuum, check for any blockages and check that the rollers in the cleaning head will turn by hand. Also, give your filters a clean. Any of these could cause the vacuum to overheat.
If you've already done this and/or power doesn't return after 15-30 minutes, I would start by checking the switch.
A couple of questions . . .
1. Does the power switch feel "normal" - basically does it have a positive feel when you switch on and off?
2. How long had you been using the vacuum before it stopped working?
Oct 28, 2010 | Bissell 3750 Lift Off Bagless Upright...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Eureka altima stopped power mid vaccuming, have changed outlits
make sure all your filters are clean,try to turn the brush roller by hand a few times if it turns real freely then the belt is broke.if it is reall hard to turn then you have something wrapped around the ends of the roller where the bearings are.your motor guard might be keeping it from running because it got too hot take the brush roller out and the belt let it cool down for 20 minutes then try it without the roller and belt.you should be able to take the ends of the roller off by just pulling out on them so you can remove what ever is in there
Mar 21, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
I was vacuuming then all of a sudden the vac turned off and wont go back on. i thought the bag might be full so i emptied it and still it wont go back on
Greetings from GoVacuum.com,
There maybe several things wrong with the vacuum at this point. When a vacuum cleaner doesn't turn on, it usually is 1 of several things. It's either a reset button on the machine, the cord, the plug, the switch or the motor. One of these things have gone bad in your machine.
If you'd be so kind as to let me know your make and model, I can help you diagnosis the vacuum to find out what went bad.
Please email me your make and model to chris.jones@govacuum.com
Chris Jones
GoVacuum.com
Oct 15, 2008 | Vacuums
Dirt Devil Upright Bagless
The cord may be bad, you may want to have it replaced, or have it checked before you get a bad shock.
Mar 12, 2008 | Dirt Devil M087500 Bagless Upright Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
139 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
