Question about Acme Titanium Replacement Blades, for Rotary Trimmer
Relpace electric grass trimmer blade
Does the nut come off counter clockwise
  • 83 Answers
Clockwise
Posted on May 12, 2009
How do i remove the entire string spool head from my 14" Electric Grass Trimmer, Toro Model 51480A.
the nut or retainer that holds the head on or is part of the head is a left hand thread
so to undo it the action is as if you are doing up a normal nut
turn it clockwise to undo
Oct 12, 2016 | Toro Garden
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
Do the graphics on the blade face up to the mower or down to the grass when fitting a new blade?
Many blade has grass side stamped into the metal.
You want the cutting to be on the leading edge either way; otherwords, the cutting sharp edge leading. Most blades also turn clockwise when viewed from the top and counter clockwise when viewed from the grass side
Apr 06, 2015 | Garden
Replace blade
Usually, but not always, they turn clockwise so that the rotation does not unscrew the lock bolt or nut. If the lock bolt or nut is reverse thread, it probably turns counter-clockwise.
Consider including more details in your questions, it makes answering them specifically, easier.
Sep 08, 2014 | Garden
How do you convert the Echo grass trimmer model SRM-22ges to the brush cutting option?
There is a hole just above the grass trimming head that you can slip a screw driver into. Turn the head so that the inner and outer holes align where you can put a screw driver or other hard steel object in. Put it in there and then turn the head counter clock wise until it comes off, it may take a little effort to get it to move, but you should be able to do this with your hands. Once you get the trimmer head off, put the blade on and hopefully you still have the nut and washer accessories to hold the blade in place. You will need to place your screw driver back in the alignment hole to hold the head from spinning while you tighten the blade nut back down. Make sure it is tight, you don't want that blade coming off at ~10,000 rpm!
Aug 23, 2014 | Echo Garden
How do I loosen the blade nut on my Ryobi 4 cycle edger? Which way does it turn??
Try heating the nut slightly with a gas torch and continue to turn counter clockwise as the manual suggests to undo.
The heat will expand the nut slightly making it easier to undo, don't overheat the nut as this could damage it.
check their isn't any locking washers holding the nut in place, bend the washer out of the locking position if this is the case.
Try using a larger spanner or extend your handle to give you maximum leverag
Jun 28, 2014 | Ryobi RY13050 4 Cycle Wheeled Edger Lawn...
Trying to replace the blade on my Craftsman edger; the nut holding the blade won't budge - now I'm not sure which way to turn it to get the blade off!! Clockwise? Counter-clockwise? Thanks. Larry...
Take a little break and spray the shaft where the nut is on it with some PB Blaster or Liquid Wrench penetrating oil. Let it soak tonight and turn it off counter-clockwise tomorrow. If you can fit a good sized box wrench on in, turn the wrench down towards the ground and give it a few good whacks with a rubber mallet or hammer. Try not to strip the head of the locking nut.
Oct 29, 2010 | Craftsman Garden
Replace blade on electric lawn mower
IF IT IS A CORDED MOWER MAKE SURE IT IS NOT PLUGGED IN -
IF IT IS CORDLESS, MAKE SURE SAFETY DEVICE (KEY) IS REMOVED
If you have a work bench, place your mower on the bench on its side or upside down where you can see what you are doing. If no bench, the floor of your garage or your driveway will work too.
Get a small 2 x4 block, a C-Clamp or some other device to keep the blade from spinning.
Get a ratchet or breaker bar and socket to fit the bolt in the center of the blade.
After you are sure the blade is blocked from spinning, turn the socket and ratchet to the RIGHT (clockwise) to loosen the nut until you can completely remove it.
When you install the new blade, look at it to see if it is marked "grass side" if it is not marked, the sharpened area on the blade should have the "beveled" edge toward the housing and remember the nut will turn to the left (counter-clockwise) to install and tighten. (Electric mowers have LEFT HAND THREADS due to the rotation direction of the motor.)
Oct 08, 2009 | Black & Decker 18", 6.5a Electric Mower
How do you take the spool off the Homelite gas grass trimmer?
Push in on the spool & turn counter clockwise. This works for most trimmers. Careful though, the center spring may pop off with the spool. (I wouldn't do it on a hill)
Aug 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Acme Titanium Replacement Blades, for Rotary Trimmer  Logo
159 people viewed this question
Top Acme Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Acme Tool and Hardware - Other Expert? Answer questions, earn points and help others
