Question about Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV
Blue lines on screen, Manual convergence and volt adj does not help.
Looking for DS board (P/N: A1405077A) for a Sony KDP-51WS550. Contacted Sony and they said the board is no longer available. The issue is that the blue manual convergence is limiting and does not allow the + to match up with the others. Picture has curve blue lines, plus the LED up front blinks 7 times when I turn on the TV. Did voltage adjustments on the FOCUS panel (front of TV) and it did not make it go away. Last resort I can replace the STK's (and fuse/resistor), but looking a complete board to just replace. Thanks!
  • wilmer370 May 11, 2009
    Awesome! Weird that the refurb cost more... I placed the order and hopefully this is the fix! Thanks!
  • Anonymous May 12, 2009
    Well, that place doesn't carry it anymore or their supplier doesn't carry it anymore; I guess I'm off to changing individual components... Need to find reputable place to buy the STK's and pico fuses.
  • 6,784 Answers
HI. i have found a DS Mount(Board), that matches the model number given. it is available for purchase online and can be delivered to your address as well via ups/fed x. I will post the link to the site where you can order asap.
CLICK HERE TO BE DIRECTED TO THE PARTS STORE FOR YOUR REPLACMENT BOARD(DS MOUNT).
Posted on May 11, 2009
  • Michael Masters
    Michael Masters May 11, 2009
    Please rate and god bless:)
I have a KDP51ws550 tv that has convergence problems. Flash focus would not work and neither would manual convergence. I replaced the both convergence ICs and checked the pico fuses, turned the unit back...
Check your soldering. Check the vertical power board on the far left when looking from the back. It has fuses on it as well.
Depending on quality of STK chips, they could have been bad or failed right away. Best things is to look at the schematic, verify what colors you can move and see which STK chip is not functioning.
If both chips are not function after replacement, likely a fuse. Be sure to verify the resistors next to the STK chips.
Mar 06, 2011 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony TV
hello AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly
regards
shaun
Feb 11, 2010 | Sony Grand WEGA KDP-51WS550 51" Rear...
My service tech said my d-board can't be replaced/repaired
He was wrong, Sony doesnt have them any longer, But you can get remanufactured ones that have the same warranty as the new ones used to. Check with www.tvrepairworld.com They should be able to get one.
Jan 05, 2010 | Sony Grand WEGA KDP-51WS550 51" Rear...
My Sony KDP-51WS550 wont turn on anymore. The Standby light is flasshing 10 times.....Any ideas about what happened and how to fix?
Type in space bar Understanding sony Blinking codes this will take you to a website telling you what each code means.
Nov 13, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
SONY KDP51WS550 NEEDS ITS D-BOARD REPAIRED OR REPLACED
Below is an exploded view shows all boards location in KDF-51WS550
Hope this will help you to identify required D board.
Mar 04, 2009 | Sony Grand WEGA KDP-51WS550 51" Rear...
KDP-51WS550 with 10 red led blinks upon power-up
I have a power supply board(g) a audio board and video board and all other boards that im looking to sell they are all good might sell cheap cal me at 573-433-1925
Oct 09, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony tv
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram.If you can then let me know..
Oct 19, 2007 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony Grand WEGA KDP-51WS550 51" Rear Projection HDTV Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
