Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag dishwasher DWU7560AAM
After the dry cycle is complete, there is a residue left on my dishes, I added Jet-dry and it did not help. I also tryed using less detergent. The problem just started.  I use gel or liquid detergent, Palmolive or Cascade.
  • 1 more comment
  • Ben Ammons Nov 23, 2007
    yes, I have the DWU8260AAX and all of a sudden, after years of problem free use, after the rinse cycle there is always this baby-powder like dust on all the dishes in the bottom rack and it seams the top rack isn't getting quite clean. We tryed a variety of different soaps and drying agents thinking it was some bad or old soap, but it keeps appearing like magic every time we run it. White, fine, dust of some sort.
  • mossygirl1 Nov 27, 2007
    I have the exact problem. My glasses all have white residue inside them. I have used all kinds of rinse agents and nothing helps.
  • bigmouth3280 Oct 30, 2008
    I have the white powder residue also. I've tryed soaking the sprayers with CLR also bought the dishwasher cleaner. None of these work...Fed up... now washing by hand. Dishwasher is only a couple years old.
Check your water spray bars. I'll bet they are plugged with calcium or something.
Posted on Nov 23, 2007
SOURCE:
GE TRITON dish washer. Utensils are stained after wash. I tried all that suggested solutions like cleaning with white vinegar, make sure hot water flows before it starts. I donot think we have hard water...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 21, 2011 | Maytag Dishwasher
I have detergent buildup/residue in the dishwasher and dishes. I've used Jet Dry and have made sure to run the water hot just before starting the cycle.
heatman101
Dec 27, 2010 | Asko 24 in. D3450 Dishwasher
I have an older GE dishwasher Model # GMB921HB119. The machine operates normally till it reaches what I believe is the final rince cycle and stops. The timer continues to advance, reaching the drying cycle...
heatman101
0--0
Dec 26, 2010 | Maytag Dishwasher
There is a film like residue on dishes after complete cycle has ran. I use cascade tablets and also have refilled the jet dry. It is on all dishes but the glasses and clear plastic show it the most.
heatman101
Dec 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishes have a white scaley residue left after the dishwashing cycle is completed.
heatman101
Dec 02, 2010 | Maytag 24 in. PDB1420 Built-in Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Residue left in glasses and a film on the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 09, 2010 | Maytag 24 in. MDBH940AW Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
How do I get the Electrolux dishwasher to dry the dishes?
Hello, I've got a suggestion and at first it may sound like I'm pulling it out of my...left field. I'll tell you the what and then I'll explain why. Try this, take a rag or paper towel and soak it with "rinse aid" AKA, "jet dry" and apply it to the top of the tub and to a lesser degree the sides as well. I suggest this to all my customer's with new dishwasher's. Now the why...all dishwasher's require assistance to dry your dishes, some more than other's. Hence the need for an additive such as jet dry, it is simply a wetting agent which help's the water run off the dishes and as a result they dry better. So why put it on the tub ? Glad you asked. The reason is exactly the same, on older dishwasher's that have had many year's of use the tub has already built up some wetting agent on the tub just by normal and continued use, the new obviously has not. The only jet dry the new one has is the added amount in the dispenser. Over a short time of regular use the unit would start to dry better on it's own, this just speed's up the process. By adding the jet dry to the tub you create a seathing action allowing water to run off before & during the dry cycle as to not have water in the form of condensation dripping back onto the dishes when the cycle is complete, which leaves you with dry dishes as opposed to wet dishes. Make sense ? I hope so, it really work's. Hope you found this helpful. If so please rate the info you received frome jere at "fixya" today and good luck. Let me know if I can assist you further. I hope you didn't find this too difficult to read, I had to use my iphone, it's the only internet connection I have at the moment. Macmarkus :)
Jan 07, 2010 | Electrolux EIDW6105GW 24 in. Built-in...
Soap is leaving residue on dishes
Hard water, add finishing rinse, rinso, jet dry etc, plus clean the inside once in awhile too!
Aug 25, 2009 | Dishwashers
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
239 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
