Question about Lexmark Optra T610 Laser Printer
Our Lexmark T610 laser printer
Being used in a library setting, keeps "spitting out" reams of paper when patrons print from one of our floor computers. Each page has a line or two of mishmash printing on it. We've tried everything we can think of but the only thing that will stop the printing is to shut the printer off. Please help!!!!!!!
  • 26 Answers
You have the wrong drivers for the printer. You maybe getting weird characters also. When you turn it off it clears the memory buffer (print job). I assume it seft tet OK. Delete and reload drivers
Posted on Jul 24, 2009
Lexmark t614 manual feed how it works
  1. Push the lower release latch. The multipurpose feeder door drops open.
  2. Pull out the metal bar in the recessed area on the multipurpose feeder, far enough to accommodate the paper you will be using.
  3. Slide the paper width guide to the far right.
  4. Prepare the print material for loading:
      • Flex paper or fan envelopes back and forth. Do not fold or crease the paper. Straighten the edges on a level surface.
      • Hold transparencies by the edges and avoid touching the print side.
      • Fan the stack of transparencies to prevent jams.
      • Be careful not to scratch or leave fingerprints on the transparencies.
  5. Use the stack height limiter as a guide for stack height when loading print materials.
  6. Load one type of print material in the multipurpose feeder. Do not mix types.
  7. Slide the paper width guide over until it fits snugly against the side of the print material.
If you need further assistance please contact Lexmark Technical Support.
Aug 24, 2011 | Lexmark Optra T610 Laser Printer
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
May 01, 2010 | Lexmark Optra T610 Laser Printer
Stopping the lexmark optra t610 from resetting
sounds to me like a dead back up battery. I think you'll have to call a dealer to confirm this, and they would have to replace it for you
Mar 14, 2009 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 keeps saying "change tray one to plain paper"
3 possibilities
1) the paper size sensor in the tray(those teeth on the size of the tray) is broken
2) The sliding paper guide is not pointing precisely at Letter
3) Your paper type is set to something other than Plain Paper.
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Optra T610 Print Problem
Your paper size settings for Tray 1 is probably wrong. Make sure it is set to Letter and the type is Plain Paper. If your Paper size is Universal, then either the paper guide in the tray is set wrong or the paper size sensor is broken. If the sensor is broken, you can disable auto paper size sensing so the printer will allow you to specify a paper size. To disable paper size sensing, you need to go into Config Mode. The other way is to send a PJL command to the printer to disable the function.
Nov 07, 2008 | Lexmark Optra T610 Laser Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
244 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
