Question about Kenmore HE2 Plus Front Load Washer
Code 5d comes on and it stops running
What does the code 5d mean
  • 460 Answers
5d means the follow; possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. "Was this helpful?"
Posted on May 11, 2009
What does code 5d mean
Hi Joyce,here's a link on your code 5d and what it means. ShopYourWay
Feb 16, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Kenmore model 110
Per Sears Repair Site code 5d is actually SD. Indicating suds detection. It displays when a drag is detected by basket of a suds lock condition. This is generally caused by using too much laundry detergent or the wrong type.
Apr 13, 2014 | Dryers
My washer is displaying a 5d code on panel, what does this mean?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 01, 2011 | Kenmore Front Load Washer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
What does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Oct 20, 2009 | Washing Machines
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Kenmore HE2 front load error 5d
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck.
Nov 12, 2008 | Washing Machines
Code 5d
its a water senser error code check for loose wire bottom front of outer tub ,i have never had a bad one "less soap plz"
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore HE2 Plus Front Load Washer Logo
657 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
