Question about Kenmore 23822 Top Load Washer
Roper top load washing machine that won't aggitate
I have a roper top load washing machine that won't aggitate or spin, any thoughts,,,,cheaper to get a new machine? this one is 15 years old
    President:
  • 1,136 Answers
Hi, It is most likley that the coupler is bad. The coupler connects the motor to the transmission. If the motor runs and you get neither spin or agitate, this is the most common problem. If this is something you want to try and fix, you can go to 222.whirlpoolsurplusparts.com and there I have a detailed article on how to change the coupler.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
Posted on May 11, 2009
Roper washer rax7245awo won't spin/aggitate
is this a top loader??there are clips on the edges of the top..they require use of a regular screw driver(flat blade) inserted between the top and sides..them it should pry up and tilt to the back..on hinges..
Feb 02, 2014 | Roper Washing Machines
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 10, 2011 | Roper RAS8445KQ Top Load Washer
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
Won't spin out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Roper RAS8244KQ Top Load Washer
The washing machine doesnt aggitate
heatman101
May 14, 2010 | GE WBSR3140DW Top Load Washer
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
RAS6233KQ0 Doesn't Spin
Manually set it for SPIN and turn it on.
If it does nothing at all,
You have a defective lid switch.
Jumper the lid switch and see if it spins.
If yes, replace the lid switch.
Feb 27, 2009 | Roper RAS6233KQ Top Load Washer
Washer wont aggitate, spin or drain
Your drive belt sounds like the problem related to all these, provideing you hear the motor running, and timer is advanceing
Feb 10, 2009 | Roper RAS8445KQ Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Kenmore 23822 Top Load Washer Logo
96 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
