Question about Wacom (PTZ930AC) Graphic Tablet
Can not install ArtZ tablet
I followed all the instructions in the manual but i did not have the driver disk so I went to the Wacom site and downloaded the windows XP version of the drivers. The instillation process does not recodnize that I have a tablet attached to my computer. I know that my computer is recodnizing the tablet because the light is glowing orange and when i put pressure with the pen on the surface the light turns green showing that the tablet is seemingly working properly. The only problem i have with it is the driver it does not recodnize that i havea a tablet attached.
  • rugged Apr 24, 2008
    my wacom tablet was installed and has been used successfully for more than  2 years.  then I got someone to upgrade the memory on my mac book, and then the pen was all over the place, not within the screen confines.  I deleted the software, and followed instructions to reinstall, but it says the installation was successful, but an internal problem in the tablet caused it not to connect.  When i click on wacom in apple preferences, it says no tablet is installed.  What to do now?
  • pfaelt Aug 22, 2008
    When my formal Apple crashed I bought a new one but I lost the installdisk of my Wacom CTE -640 . So how can i install my Wacom?
Uninstall the Wacom software, but don't reboot just yet. If you are using a Serial to USB converter, note the port it is using. If you are serially connected, note the port also. Wacom tablets seem to only recognize ports 1-8, so you'll have to remap your port to a free one in that range. In Device Manager, select your port (you may have to click view and show hidden devices). Right click on the device to expose the Properties. Select the Port Settings tab, then the Advanced Button, then change the COM Port Number to an unused value between 1 and 8. OK you way back out. Reboot, reinstall the Wacom software, and do a manual search for the port you just assigned. Reboot to complete the installation, and you're done. The TabletService hangs if it does not get the port it thinks it should and does not stop correctly. I set mine to disabled and also disable the tablet in the control panel, just so I can avoid reboots when changing ports, but that is another question answered.
Posted on Mar 13, 2008
Check the port it is connected to. Wacom seems to only recognize serial ports 1-8. I use a USB to Serial adapter and had to reassign it to a lower port number from 12. Go into Device Manager, select the connected device, right click to select Properties, the the Port Setting tab, Advanced button, COM port number. Ok you way back out. uninstall the Wacom software, then reinstall it, following the reboot prompts. It loads a service that tends to hang if the device is not connected when it starts. I had started disabling the tablet and the service just so I can avoid a reboot when I change ports.
Intuos3 and Mac OS X (10.6)- No preferences menu/program/software
hello, just go on the wacom site and download the newest drive for mac os x, i was having similar problems, but now everything's fixed and it's working fine!
go to the following link,
http://www.wacom.com/downloads/driver-detail.php?id=215
Jan 03, 2010 | Wacom Intuos3 Graphic Tablet
Can I connect my old Mac's ArtZ tablet to a new PC using ADB-to-USB adapter ?
You can try the Virtual Tablet Interface from Digitizer Technology: http://www.vtablet.com/
I haven't been able to get pressure sensitivity working in my drawing programs yet, but it does allow you to use the tablet in Windows 7.
Oct 06, 2009 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Vista driver solution for Wacom ArtZ II Graphics Tablet?
Have you actually tried installing the XP driver in Vista? Sometimes that does work, so no harm in trying. Use the compatibility mode in Vista to install XP drivers to increase the chances of succeeding.
Apr 17, 2009 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Am looking for drivers whichi wil support to use pen on my gateway m275laptop (because it was formated)
From the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Apr 03, 2009 | Gateway M275 Tablet PC
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
Jan 17, 2009 | Gateway M275 Tablet PC
Older ArtZ II with ADB cable won't talk to my laptop
I'm thinking this is a Mac-only tablet. The ArtZ II for Windows came with an rs232 (old mouse) port at the end of the cable, in addition to a built-in spot where the power plug attaches.You didn't mention the power plug on yours, so the Mac version of the tablet must have the power routed in through the cable.
Short answer, the reason the light isn't coming on is because the tablet isn't receiving power. If you go get a cross-platform adapter card for plugging in Mac hardware on your HP, it *might* work.
Nov 25, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Wacom artz II
maybe, go to manufacture web site see if they have a download for this model they may have discontuned the product..sorry..
Jul 08, 2008 | Wacom (PTZ930AC) Graphic Tablet
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Wacom (PTZ930AC) Graphic Tablet Logo
244 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
