Question about Samsung Televison & Video
2 pixels turned white
Have a Samsung dlp 46 Hlt75S that has 2 pixels turned white on all input sources
  • 3 Answers
Here is the solution, it's on a forum. You problem is a faulty DLP chip on the DMD board:
http://www.avsforum.com/avs-vb/showthread.php?p=16445994&posted=1#post16445994
samsung claims it is not a problem, but I've seen HUNDREDS of people with this problem. A facebook page has been made to attempt to get samsung's attention:
http://www.facebook.com/home.php?ref=home#/group.php?gid=76261763079&ref=mf
Posted on May 12, 2009
Samsung dlp has static
I have seen this happen quite a bit. For some reason the input (cable jack) works loose from the board. I would try running your source signal (cable/dish) to another input on your tv...such as S Video/HDMI/Composite or whatever you have available.
Jan 07, 2013 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I have a 42" samsung rear projection tv which has developed 1 white dot about 1/16" it has been there for about 3-4 days. Is this a sign of more trouble to come? Can it be fixed, or is this a warranty...
It is a dead pixel and samsung will not honor any warranty on dead pixels under 20 of them. It is considered within tolerence level despite it being a damn pain and a fault that shjould be rectified by replacement.
But you can try.
May 12, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots all over screen
Sounds like DLP chip not making good contact or bad. It's not soldered, but spring clamped down to contacts.
May 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots are just emerging on my 46inch
There seems to be an issue with your DMD board, which is the on in charge of the pixelation. What you can do to confirm if it's indeed the DMD board, is the following: GO to the menu on the TV and if the dots show in the menu, it's your DMD board, but if they don't the issue might be with one of your Video Boards.
Dec 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp white dot
If the white dot is on every picture and every input and stays there for a sec. after you press the power button to turn off the tv then suspect a stuck mirror in the DMD.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
Mine is having the same problem. It started around Memorial Day and is only getting worse. One white dot is now a dozen. I called Samsung several times and was given the brush off. They clearly know this is a problem and are failing to respond to the problem in hopes that people will deal with it on their own. It does not matter if your warranty is expired. This is a latent product defect. They are still liable and obligated to fix the problem. I have filed a complaint with the better business bureau. If the company does not respond, I'm taking this to small claims court to get reimbursed for any cost to fix my tv.
Jun 02, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
157 people viewed this question
Jerry Greenberg
Jerry Greenberg
