Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
  • Gerry Millward
    Gerry Millward May 11, 2010
    Whoops, sorry, it isn't listed under C48, but "all printers". However, my advice is the same - resubmit it under the correct printer type.
  • Gerry Millward
    Hi jcymbor
    Clarification is needed. Paper jam symptoms and solutions are different from printer to printer, so we can't treat it as a "generic" problem. Can you confirm first which printer you are talking about since the symptoms you describe don't fit an Epson C48 (which the problem is listed under). If it is a C48, can you describe the symptoms in more detail.
    If it isn't a C48, can you enter a "solved" post under this error, then resubmit it under the correct printer type.
    Problem Solver:
  • 14 Answers
Hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
Posted on May 18, 2009
The screen says the "back cover is open" and
If you turn the printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Jan 24, 2011 | Brother DCP-7020 Black and White Copier
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Error Message - Paper Jam
I had a paper jam. I removed the offending sheet of paper which unfortunately tore into 4 pieces as it came out. Upon piecing the sheet of paper back together - there is a small piece missing. I've checked the printer thoroughly - nothing can be found!
Feb 25, 2009 | HP Officejet Pro L7680 All-In-One Printer
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Printing Problems
Turn machine on..
The unplug power cable on the back....
Press & Hold # 3 while connecting power cord.
keep it pressed & hold till screen display reset or shuts down...
Then follow the prompts on screen...
If this will not resolve the issue , then replace
call 1800 474 6836 & request them upgrade , You will save some money on purchasing new.
Apr 26, 2008 | HP OfficeJet 6110 All-In-One InkJet...
112 people viewed this question
k24674
jasbo
jasbo
