Question about Lexmark E332n Laser Printer
Paper jams . changed cartrage still jams - Lexmark E332n Laser Printer
Hello, I called a tech friend. He says it is VERY likly it ids the printer fuser that is preventing printed material to complete path.
I have exchanged said printer with a exchange service. I will followup with you for resolve of fuser .
gcoll3
Posted on May 12, 2009
Mp130 cartrage jammed. computer message says that the paper is jammed. but their is no paper jammed.
The message on the computer is rather generic.. you will get a paper jam message for many different problems. the series of flashing lights on the printer is a more accurate way to tell what is going on. go to the troubleshooting section of the Canon website to get an accurate idea. Most likely it has a broken paper pickup shaft.
Sep 30, 2010 | Canon PIXMA MP130 All-In-One InkJet...
1500 series all in one.check cartrage or paper light is blinking
Hi There
Try cleaning the Contacts on the cartridge not making proper contact with the print carriage.
All the best Pineworks
Apr 01, 2010 | HP PSC 1510 All-In-One InkJet Printer
Same problem help
first try to remove the ink cartrages and close the lid after doing it.
after the system recognizes that there are no inks replug the ink cartrages and turn of the printer and PC/NB and after about 10 secs. turn all of the devices on and try to check it again.
Aug 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Flashing : attention required
It could be a paper jam cartrage or carage jam or the ink needs to be changed
May 01, 2009 | Office Equipment & Supplies
The printer says I have a paper jam. There's none,but it won't wo
One of the paper sensors is probably stuck. Some disassembly may be required to get to them. They are normally small plastic rockers that will let a small IR device either allow a beam of infrared light to pass or block it. On this printer, I would guess that there are 2 of them. One located at the paper feed so it knows if there is something in the tray or not and the other is probably located at the back where the paper curls back around to pass beneath the print area. There could also be a thrid at the output tray, but with this particular model, I kind of doubt they put one there.
Apr 14, 2009 | HP PSC 1215 All-In-One InkJet Printer
I had a paper jam, and now every time i try to print it jams the ink cartrages , one paper jam and now it will not work
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | HP Deskjet 5440 InkJet Photo Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Paper jam
The problem is the Fuser unit. It may cost more that what the printer is worth.
Joe
Oct 09, 2008 | HP LaserJet 4 plus Printer
Printer not printing says to see user guide unable 34
i had this problem, paper was jammed in between printer cartrage and the right wall ( when lookin at it from front).
open top flap of the printer, u will have access to the cartrage (the thing that moves side to side whilst printing) move that to the left and have a look on the right hand wall. you should see quite a bit of paper jammed up in that area, make sure u clean throughly, get a torch if psooible, close flap then ure eon ure way
Sep 12, 2008 | Office Equipment & Supplies
Dell A920 Paper will not go into the printer without a jam.
check cartrages plz your cartrages ok after you clean pickup roller i hope your pro. solve
Dec 20, 2007 | Dell A920 InkJet Printer
Lexmark E332n Laser Printer Logo
169 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
