Question about Tomtom GO 720 GPS Receiver
Tomtom one touch screen not working properly
The tomtom turns on fine....but when you try to touch a letter or number it jumps to a different letter or number , we tried resetting it but still having the same problem and the unit is fully charged.....help please!! touch screen does not select the letter i touch
    Problem Solver:
  • 3 Answers
Here is the cal.txt I used for my 720
929 86 480 75
It is really close to perfect
open a text file put these numbers in save as cal.txt copy this file connect tt to computer go to explorer/aka file manager find tomtom drive and paste it in.
That is it. test it out.
Posted on Jul 20, 2012
  • d cart Jul 20, 2012
    929 86 480 75
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
Sounds like the calibration has gone on your touchscreen. Unfortunately there is no fix for the tt like you can with Magellan and garmin.
Posted on May 12, 2009
3 Suggested Answers
fargohill
  • 6 Answers
SOURCE: tomtom one touch screen not working properly
we can help solve this problem, we have touch screens for replacement
Fargohill
Posted on Jan 13, 2010
To get it working again, I used the option to change settings and turn the screen 180 degrees. After that at least you can use the buttons again. I have no answer yet for the adjustment trick, but a new touchscreen is not the answer. It may have something to do with buying charts ready on disk, most people do not know if the map they order is the proper one for the model. This can be checked with tomtom home. Once you have turned the screen 180 degrees, you have a better look on where to push to make it work.
Oce I have a better solution, be sure I'll post it.
Posted on May 24, 2010
Touch screen gives wrong letters when touched
Hi, Try using something like a stylus to type in the letters. I've found with gps' that the touch screens aren't that accurate and almost all fingers are too big to properly type in anything and since a stylus (or even a stick) is much smaller it should be more accurate.
Jun 22, 2011 | Tomtom GPS
The touch screen is not working properly when you
Turn the unit off and make sure the power cable is disconnected as well, get a good SCREEN cleaner. Not the same as Windex or other product. Clean the screen well, you need to get rid of the oils and dirt on the screen. Once you are finished and the unit has been dried off power the unit back up and in one of the submenus you will find a screen calibration option. Use this and you should then be finished and the unit should go where you touch. Hope this helps
Jun 19, 2010 | Tomtom ONE 3rd Edition GPS
MSI keyboard does weird things
I have a MSi laptop, and whenever I am typing, my cursr ejumps all over the place! Onto different lines, in the middle of other words. Why?? Please help!
May 15, 2009 | Intel Motherboard
Cracked touch screen on tomtom one I would like to know the part number so that I can locate one on line please thank you
The part number for Tomtom ONE screens are different depending on the version. You can find the replacement screens for Tomtom ONE V2, V2 and V3 in www.Pantallas.biz.
May 05, 2009 | Tomtom ONE GPS Receiver
After inserting a 1 gig sd card and copying the relevant software across using tomtom home, the unit switches on then goes to a screen that says please wait in about 5 different languages and an egg timer,...
delete everything on the card with windows i.e. double click on my computer select whatever drive letter it has asigned to the memory card in your TomTom unit, then select all and delete. Then restart TomTom home copy relevant software across or use the backup facility and everything worked just fine.
Jul 31, 2008 | Tomtom GPS
Tom Tom 720 keeps jumping to main menu
Well I finally figured it out for those who might run across this problem.
It seems that when it got hot and expanded the grey bezel around the screen would touch the screen just enough to activate it. I gently pried the bezel up just a bit and it seems to have solved the problem.
From Ban One
Jul 25, 2008 | Tomtom GO 720 GPS Receiver
Fargohill
Mar 22, 2008 | Tomtom ONE GPS Receiver
No response from touch screen after reset
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 23, 2007 | Tomtom GO 910 GPS Receiver
Frozen startup screen
jump up and down on it about 27 times sorry 28 and see if that helps, it did me - i then went and bought a MAP
Oct 24, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom GO 720 GPS Receiver Logo
2,949 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
