Question about Dell Latitude D600 Notebook
Cd drive not getting listed
Whenevr i go to my computer i dont my cd drive so that i can open any disk
  • 790 Answers
Hello!!
Go to device manager ... by right clicking on Mycomp select on the cd-drive and enable the device..
Thank you!
Posted on May 11, 2009
How do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
My gemini cdx2400 not reading the dis
Are you saying your computer will not read a disk?
Is this a disk you made or someone made and gave to you? If so most there are times when the computer will have trouble reading them.
Try using a store purchased disk such as a music cd that you purchased. If it reads and plays it, then the drive is ok.
Click Start/My Computer and see if your CD Drive is listed as a device. If not, that's your problem.
If the CD Drive is not listed as a device, then remove the power cord, open the case and remove the two cables that plug into the cd drive then plug them back in. Then try rebooting and see if the cd drive is listed as a device in My Computer.
If the drive is still not listed, then you will need to Remove Upper and Lower Filters.
Apr 22, 2012 | Computers & Internet
My cd drive isn't working at all. I am trying to install my Norton Internet Security 2011
Go into your control panel and under device manager look to see if it is listed in there and no exclamation marks beside it. Also try another disk just to rule out a defective disk
Mar 19, 2011 | Toshiba Computers & Internet
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
Dvd disk drive not showing in my computer
Hi!
The chances are that the drivers for them got corrupted and you can install them fron your motherboard cd. To install them go to Control panel-> add new hardware-> search for new hardware-> if it shows up then its good else add them from the list. It will then install the drivers from your motherboard cd (the cd you got with your system or from the cd you got with your disk drive).
If this doesn't help then check for the connectors(going into disk drive from power supply and motherboard) by opening your pc.
Please rate the solution.
Thanks
Rylee
Feb 08, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
Dont know how to upload pics to computer
after connecting your camera, power it up. the computer will then prompt new hardware found and is ready to use. in most cases, the camera will be treated as another disk in your computer (like usb disk). go to my computer and check if there is a removable devices listed. open that drive then you may start to copy and paste it on any folder of your computer.
the camera should also come with a cd, which you may install in your computer.
Oct 31, 2008 | HP Photosmart M425 Digital Camera
Pen drive not being accessed
Try installing the firmware again through the CD provided with it.
Sep 17, 2008 | Transcend T.sonic 610 MP3 Player
Printer won't connect
I think you need to press on the (Have a Disk) button and install your printer cd - which came with the package - into the CD-Drive
when you open your CD-Directory, the needed info file will be automaticlly selected, all you need to do is pressing (open) button and then (next) from the printer installing wizard.
Hope that was helpful.
Mar 19, 2008 | Computers & Internet
Gigabeat System Error Problem
Error message 0000020 - System Error displayed whenevr devide powered up. Only way to shut down is by turning battery off. Gigabeat Software on PC not able to detect device, not listed in Device Manager or as an external drive in My Computer. (As it normally is) Is there a way to reinstall firmware from PC when device not detected?
Aug 14, 2006 | Toshiba Gigabeat MEG-F20S MP3 Player
Dell Latitude D600 Notebook Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
