Question about Dell Inspiron 1525 Notebook
Computer said that the ide device is not working, how do i fix it
  • eckomoe May 11, 2009
    it helped me understand
  • Dell Master
  • 4,806 Answers
Hi there.
The IDE device is the hard drive, if the system says its not working then it will have to be replaced, there is no way of fixing it.
Please be aware that this is a common problem so your not on your own.
I recommend the you purchace a Seagate hard drive as they come with a full five year guarantee.
Good luck and thanks for using FixYa!!
Posted on May 11, 2009
Messed up an IDE partition now BIOS won't recognize drive, can this be fixed or is there a workaround?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? Hope this helps.
Dec 09, 2012 | Computers & Internet
The computer is not booting with ide hard disk but it is booting when i fix a sata hard disk
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
for usb drives
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
hope this helps
Oct 30, 2012 | Foxconn 45CMX socket LGA775 motherboard...
Repair isatap drivers windows 7
if the drives are working, leave it be. There can be false positives. If the drives are slow or some thing else is odd, try the following solutions. Try to locate the driver needed by going to system devices and looking for a yellow or red icon next to a device. If there are no marked devices, you are probably ok.
Computer icon, properties, select device manager.
Open the properties for that device. details tab, properties and select hardware id. Copy the hardware id information and google it (sample:IDE\CdRomATAPI_iHAS324___B_______________________AL1A____ trimmed and adjusted becomes IDE\Cd Rom ATAPI iHAS324) Find drivers for that hardware if you can and update. You can also just uninstall the device and click rescan from the device manager menu. It should reinstall.
May 12, 2012 | Microsoft Windows 7 Home Premium 64BIT...
In the boot device menu, drive 1: no ide device what does this mean?
test for secure dust free connections or replace the 40 pin ide lead from mother board to hard drive
include electrical extensions
operating system cant find ide hard drive
hope it helps
Nov 12, 2011 | Dell Dimension 3000 PC Desktop
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
ASUS P4S533-MX hang up and not available second IDE
Turn the computer off unplug your second IDE device reboot your computer and see if it fixes they hang up and slow run if it does fix it then it is most likely your hard drive is toast
Nov 22, 2017 | ASUS P4S533-MX Motherboard
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
IDE devices not detected
Go into the BIOS and try to get it to detect from there. If there is another IDE slot, try to connect them to that one.
Sep 01, 2009 | Computers & Internet
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
Alun Cox
