Question about Xantrex Technology Trace Series Inverter / Charger 1500w
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
    Problem Solver:
  • 5 Answers
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
Posted on Aug 28, 2009
I have 2015 WINNEBAGO Sightseer when the generator is on I doesn't power up any appliances What is the problem?
You didn't indicate, but I will assume when plugged into park power your 110V AC devices (Outlets/TVs/Microwave) work?
If so that isolates it to the genset or something up to your AC/Breaker distribution panel.
Things to check in the main power from the generator to electrical main AC distribution/breaker panel:.
Some type of Breaker off at the Genset (Blown fuse?)
Some type of toggle switch/transfer switch on the wrong position
If you have a auto transfer switch it might be stuck or defective
Loose connection or a connector coming loose
Defective wiring
Jan 22, 2017 | RVs
No power on Cyclone 4100
Do you have power at the outlet where the unit is plugged in? If not restore power to that point. Next, check the main breaker to determine if it has tripped. It may look like it is on but to verify, turn it off and then back on. It should click into place. If that does not work and your trailer has a genset with a transfer switch. Check the transfer switch to make sure that it has not failed. It may be locked into the genset side and not switching back to shore power. If you are running the genset and do not have power make sure the breakers on the front of the genset are on.
Mar 02, 2014 | Heartland 2012 Cyclone 4100 KING
Dometic 57912
You may have a week cap. just pick up a new one and also install a hard start kit. should solve your problem. worst case you have a bad compressor.
Jan 22, 2014 | Dometic Rooftop RV Air Conditioner
My SW 3000 Invert/Charger works fine at the dock on shore power but will not charge or let the AC pass through the unit on my Genset. The genset runs everything else on the vessel including a 19000 BTU Air...
I have the same problem but on an intermittent basis. The first time it happened the tech suggested resetting the default settings and it came on immediately. However the problem has been reoccuring from time to time and I now have no confidence in my one month old unit.
ghart69499@cs.com
Feb 19, 2011 | Xantrex Technology Heart Freedom 30...
Hi I have a Tripplite 3636VR connect up with 3 X 200AH batteries in series. The inverter works fine when connected to city power, when the city power fails the inverter takes over noramlly, I then go and...
check the system but you may have to turn off the batteries
the inverter is charging the batteries but when mains power fails , the batteries will be discharging back through the inverter that is dc converted back to ac
if you power on a genset and the ac is not phased correctly, what you describe will happen--- inverter ac from the batteries against genset ac to the inverter-
If you had mains power on then it would dead stop the genset because of the out of phase situation
it all has to do with the 2 wave patterns for ac current from each unit being in harmony and not working against each other
Mar 19, 2017 | Tripp Lite PowerVerter APSINT3636VR UPS...
Freedom 20 stops passing good AC input after about 15 sec.
This unit does have an idle mode where it will not output without a load. What I am unsure of is if this exists only for invert mode or for both invert and pass through. Try reprogramming the remote to eliminate the idle feature and then see what happens.
Jul 30, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a 247 03 Springdale RV trailer. I want a
Depends on wattage demand of ac unit. VXA=W 110x20amps=2,0200 Watts. A 2,00 watt generator is too small. Best go for a 3,kw genset. A 5 kw will leave you room to run appliances and the ac simultaneously., otherwise you will need to watch your margin usage. I think 4.5 kw gensets are also available. Happy trails.
Jul 25, 2009 | Heating & Cooling
Converting the power to genertor
You should not have to switch between battery and generator, unless you are trying to use an inverter as well. Batteries are 12vdc, typically run lighting, water pump, furnace, fridge controls. Generator powers ac, microwave, television, and anything else that plugs into a 120vac wall outlet. Inverter may also run select loads, and possibly dedicated wall outlets, but not AC, fridge, or microwave (usually).
Most RVs / Motorhomes now have automatic transfer switches that will switch between the generator, shorepower, and possibly an inverter. Your coach is made during an era of transition from manual transfer switch (in form of heavy duty electrical outlet near shore power cord) and the automatic transfer switch.
There is no specific place where a transfer switch or generator receptacle are mounted on an RV. There are no rules or regulations tha cover this as far as I know. Your RV may also have an EMS (Energy Management System) that will control the transfer switch as well. EMS panels are typically located above the refrigerator or above driver / passenger seats in overhead compartment.
Apr 06, 2009 | Watts Onan Portable Generator - 5000 ,...
Xantrex Technology Trace Series Inverter / Charger 1500w Logo
386 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
Jimmer_9
Level 1 Expert
richie46
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
