Question about Goldstar R5050 Air Conditioner
Broken thermostat The dial on the thermostat popped out and is broken, and the thermostat can no longer be adjusted.  Does this indicate that the thermostat itself is broken,.and if so how can I fix it?
    Scholar:
  • 113 Answers
If its still blowing> cold or hot air? then the therostat is stuck!
if its just shifting air then you can either get it fixed by consulting ye old yellow pages.... OR opening it uo and getting the number/name printed on the switch and posting it here so i can direct you to a website that will happly send you a shiny new one in the mail!
good luck.
Posted on Oct 13, 2007
SOURCE:
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
Just picked up a used machine. The popper gets hot and everything seems to work fine but the popcorn won't pop. It just burns
The most common reason is the THERMOSTAT is short cycling or turning off to soon. It could also be one of the elements is not working any longer if it is a kettle with more than one? You should find the small red inducator light and monitor it during a popping cycle. If it's going out early on in the cycle that indicates the thermostat has opened and not calling for heat. Depends on the model, you can adjust it or replace it. I suggest calling a Cretors dealer.
http://www.cretors.com/dealer
Jan 03, 2014 | Cretors Goldrush Popcorn Maker
Adjusting the settings on a fridge thermostat
You've indicated that you have changed the thermostat but the model number you have given is electronically controlled via an NTC. If the the unit is built in there is a possibility that one of the following is causing the problem
a. the seal is no longer catching properly because the decor door needs adjusting.
b. the internal lamp is not switching off when door closes and is creating heat that the fridge is trying to compensate for
or
c. the fridge fan is not operating and not circulating the air to the sensor. (You can check the fan and light by pressing the switch at the top of the fridge compartment frame, the fan should run and the lamp go off when the button is pressed).
Try these first and repost if this does not help.
Feb 04, 2013 | Neff K9724X4GB
I own a White-Rodgers manual thermostat...Type 1F56N-444 (horizontal version). I own a 1-Heat 1-Cool single stage Carrier Electric Heat HVAC system. Pls answer two questions regarding the thermostat: 1)...
No that is an heat anticipator setting that should be set to the same amperage as the gas valve o your furnace.....do not adjust unless you can tell this or you coulld ruin the thermostat...
Jan 04, 2011 | Heating & Cooling
Is there a thermostat on my vulcan model number 6809L?
Every water heater has a thermostat. if it did't then the water would continue to heat until the pop off valve blew. not a good thing. The thermostat is usaully under the front panel and has a dial on it to change settings. Note that some newer water heaters have an electronic thermostat but still has adjustments.
Dec 31, 2010 | Water Heaters
I have a broken wash cycle timer knob on my whirlpool LTE5243BN0 thin twin washer/dryer. Ordered a replacement part, looks the same as my old one, threads okay, can't seem to screw it all the way on. The...
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
Oct 01, 2017 | Whirlpool LTE5243D Top Load Stacked...
Kelvinator Fridge/Freezer C 340 RM does not switch off
the problem is your thermostat in your frig.the dial with numbers on it.it is no longer sensing properly and theres nothing you can do but replace.that is as long as your dial is not broken[the plastic pice with the numbers] God bless ,tom
Jan 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Our thermostat is set on 73 degrees, but it won't heat past 67 degrees.
pull the cover off the front of the t-stat [just pops off easy] you will see alittle copper dial usually on the left left side called a heat antisapator,move it to .3 this will allow the heat to stay on alittle longer
Nov 16, 2008 | Amana Heating & Cooling
Goldstar R5050 Air Conditioner Logo
108 people viewed this question
Top Goldstar Heating & Cooling Experts
Bill Long
mark gardner
mark gardner
Dennis Boxerman
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
