Disk that came with camera doesn't seem to have drivers, nor does the official Canon support page. I'm running Win XP with Adobe Premiere editing software. Neither Premiere nor WIn Movie Maker will recognize the camera. Don't I need drivers?
If you have windows xp or higher you don't need drivers just an intel based pc, atleast 1 or 2 gigs of memory and try it with the software that came with it...if you dont like that make SURE your version of adobe works with the HDV format....make sure your settings IN the software program are correct...and viola!...MAKE SURE YOU ARE USING A FIREWIRE 4 TO 4 OR 4 TO 6 PIN CABLE no exceptions
Was this helpful?
Yes
No
Popular Solutions for Canon VIXIA HV30 DV Camcorder
the computer doesn't turn on. if its connected to a computer it turns o but if you disconnect it...
(More)
the computer doesn't turn on. if its connected to a computer it turns o but if you disconnect it from the computer it turns off
Looking at buying an "as is" Vixia HV30. The camera only turns on when set to...
(More)
Looking at buying an "as is" Vixia HV30. The camera only turns on when set to "Playback." It remains off if set to "Camera." Also, the LCD has no image but the seller says the panel is not cracked and suspects a loose connector.
I put on a wide angle lens and it works fine but now when I remove it, my camera won't focus at all....
(More)
I put on a wide angle lens and it works fine but now when I remove it, my camera won't focus at all. Seems like it's in macro mode. Any suggestions??
my battery charge receptor is broken. i charged the battery with a battery charger but now my mac...
(More)
my battery charge receptor is broken. i charged the battery with a battery charger but now my mac won't recognize the camera to import the video
My Vixia HV30 shows it's recording and marking timecode, but it will not playback video. I checked...
(More)
My Vixia HV30 shows it's recording and marking timecode, but it will not playback video. I checked all the settings to match another vixia that IS recordeing. Any suggestions?
