Question about MSI K8MM-V Motherboard
USB 2.0 doesn't work on K8MM-V with XP PRO SP2???
Hi to all! i've updated my XP PRO with SP2 in order to get the USB 2.0 with the drivers included in that update..but they still remain blocked on 1.1..even a PCI card with 5 USB 2.0 (certified) ports doesn't work prpoerly!!
When i plug a mss storage device, i always get a message that reminds me that device can be more fast..i've also tried to control the speed of the USB ports on the bios, but i didn't found anything related...
HELP ME!!!! PLEASE!!!!!!
  • rexdod81 Oct 13, 2007
    i've got the 6-usb ports with "VIA vt8237r plus"
    i've downloaded the "live update" for MSI mobo that sais to me tha there no update for my bios...
    i'm still cryin'...
    how can i do?i've to flash my bios?or there is another way to solve my problem?
    thanks!
    no need to flash bios!
    i've only tried to renew the usb drivers for xp+sp1 with a MSI's installer.. ALL DONE!!!!!
    thanks a lot!
    Scholar:
  • 113 Answers
hey!
ok now the K8MM-V has several 'chipsets' yours has 8 usbs? yes?
then you have the:
VIA VT8237R Chipset...
- Integrated Faster Ethernet LPC
- Integrated Hardware Sound Blaster/Direct Sound AC97 audio
- Ultra DMA 66/100/133 master mode PCI EIDE controller
- ACPI
- Supports 2 Serial ATA ports
- Supports 8 USB2.0 ports
ok? now:
download a new BIOS! this means read the readme.txt please!
http://global.msi.com.tw/index.php?func=driverfile&dno=2383&i=1
<<this is the xp(64bit driver set>> (incase you are missing the 2.0 or yours is corrupt)
http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=173
this is your BIOS (as i said please follow ALL instructions cause its inportant)
good luck!
after BIOS flash and driver updated go into the control panel > admin. settings > computer managment > device manager then look at the USB section and update the drivers!!
rerstart and volla!
good luck!
Posted on Oct 13, 2007
  • John lamb
    John lamb Oct 14, 2007
    great.
    too easy
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Why my audio driver failed to intall?
Try looking for a patch or updated driver for your sound system in your PC, integrated or a sound card that should be available at the manufacturers website(for mobo or integrated/external sound). After updating it should work, rather it has to because sp3 is better suited than SP2 and generally microsoft itself distributes the patches & updates. Alternatively you can visit driverguide.com, become a free member and let the Drive probe tell you which driver, including version, your PC will require to play audio/stero sounds........sodeep
Apr 21, 2009 | Intel D946GZIS Motherboard
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
Driver for Broadcom 802.11g Network Adapter #2
HI Gocha,
Try to get this driver from Intel website it might help you. Intel(R) PRO/Wireless 2200BG Network connection.
Regards,
K.Loges
Nov 29, 2008 | Computers & Internet
Sound driver problem
Go to this link :- http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Windows 2000, Windows XP/2003(32/64 bits) Driver only (Executable file) R1.99 2008/7/21 25451k GO GO GO
Click on GO
you will be able to Download the Driver and then you can install it.
Jul 22, 2008 | Computers & Internet
USB port is not working under windows xp sp 2
hi,
you can try the following steps.
Install the driver for the camera and the ipod as XP is preloaded with drivers for cameras for only selected models only.
Hope it helps.
Regards.
bzoy
Dec 30, 2007 | Soltek SL-915G Pro-FGR Motherboard
MSI K8MM-V Motherboard Logo
413 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
