Question about NorStar M7208 Corded Phone
Won't generate tones from keys when connected
Norstar M7208 won't generate tones when connected to a number with a phone tree. For example, when the other end says, "Press 2 for ..." and I press 2, there is no tone and the menu does not respond. Any thoughts?
    Problem Solver:
  • 5 Answers
Any other phones on system with the problem?
DTMF or touch tones are generated through the trunk card(s) of the sytem problem. Chances are there may be more then one phone that has a problem.
Also on the outside of things, just try calling the same number from a different phone on the system, and if possible try using the trunk/line that you did with the m7208 in question, same problem? If yes possible trunk issue. If no, then try another phone where the problem set is plugged into.
Another thing you can try is call another service that uses a touch tone menu, using the phone in question, see if you have the same problem.
Posted on Aug 04, 2009
Want to change dial pulse out dialling to DTMF tone dialing
unless your phone supports that (and has a little switch somewhere), you just can't. Get another phone, sorry !
Jan 22, 2014 | Nortel Meridian Norstar M7208 Mics Cics...
NorStar M7208 - How to remove global ringing?
This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech.
If you do know then:
First find out what line #, do F*0 then press the button and note the full number on the display.
i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
Jul 25, 2012 | NorStar M7208 Corded Phone
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Sep 10, 2011 | NorStar M7208 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 21, 2009 | NorStar M7208 Corded Phone
Hoe to make a Three way call
Make your first call, press hold. Make your second call (internal or external). Press the conference button, then the display will tell you to press the other line (the first one you put on hold).
Nov 27, 2007 | NorStar M7208 Corded Phone
Plugging it in
Your Nortel M7208 phone is plugged into your Norstar phone system (not the phone line) You would not be able to use DSL on the same phone port used by the M7208 phone. A filter connected to that port would not solve a DSL issue and could only cause problems with the M7208 phone. You may need to put the filter on the phone lines before they connect to the Nortel phone system... I don't know which system you have or how it is wired up so I am not sure how easy that would be for you.
Nov 10, 2007 | NorStar M7208 Corded Phone
NorStar M7208 Corded Phone Logo
178 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
