Question about Garmin StreetPilot C330 GPS Receiver
Updating Garmin C330
My son has misplaced the original box and other components.  I want to update the software and have downloaded it, but do not have a CD Rom or USB cable as referenced in the online instructions.
Re: Updating Garmin C330
You can use any standard USB cable to connect the PC to the StreetFinder as long as it fits.  Typically digital cameras have these cables.
Updated software can be found and downloaded from the Garmin website.
Posted on Oct 14, 2007
0 characters
3 Points
Sometimes the screen freezes on my streetpilot c330
Just reset the device. If it do not help you, update the software. download the user manual to your device from net, and go to its page [28] for details about updating firmware.
May 18, 2012 | Garmin StreetPilot C330 GPS Receiver
My garmin street pilot c330 won't aquire satillite. this unit is 2 years old, but never out of the box. i got it from my son and tried to set up. when you turn it on all of the data in the unit is...
Try connecting in your car and leave it on and let it charge while you are driving it may eventually find the satellite, it probably remembers the last satellite it found which was in Kansas. You may not be getting a signal where your are right now so run some errands and leave it connected in your car.
You can also go to the garmin web site and try updating the unit. You will need a usb cable and will need to install garmin updater. Make sure the unit is fully charged.
If this does not work you can call garmin and they are usually very helpful. Here is the garmin link which will help answer some more questions.
Let me know what solved the problem. thanks for using fixya
May 14, 2011 | Garmin StreetPilot C330 GPS Receiver
My Garmin does not connect to sateliyes
Try Raising the antenna and then press the reset button when the C330 is on,this should restore the garmin, then: Make sure the C330 is fully charged and
I would try updating the C330 by connecting to to a usb port on your computer and then downloading Garmin Communicator. If that does not help then try contacting Garmin. I will attach a link to Garmin customer support. thanks for using FixYa
May 05, 2011 | Garmin StreetPilot C330 GPS Receiver
GPS miscalculating directions
Have you by any chance done any software updating of your Garmin? They have some updates available for your unit. This could possibly resolve the inaccuracies with your unit. Try installing the webupdater for windows and allow it to update you garmin unit. You can find the software for your particular unit here:
Apr 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Attempts to download new maps failed even after updating software
You may need to contact Garmin Support at their website and have them mail you a CD.
Apr 06, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 will not acknowledge our home address
if you have a laptop take it outdoors and reload the software while sitting in your car at your home, as the software loads it also checks for nearest satellite...I did have this same problem. It took me 9 hrs. to reload the software while I was outside...I ran an extension cord to my laptop.
Oct 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Map Update 2008 software encounters error
OK WELL U CAN BUY HI END PCI USB CARD 2.0 that will do it and do a clean up run tool ok help the choking up on it
Jan 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't update software for StreetPilot C330
I have contacted Garmin several times till I got an acceptable answer. Some of the C330 receivers were sold to car rental agencies and contain software version 2.30. These units cannot be uodated. They are not reconized as a HD letter in "my computer" and mine would not accept a map update.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Hello, you can check on the Garmin website to see if there is an update - or you can go to to see if there are updates to the map software. Good Luck! Dr. Know
Dec 01, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
