Question about Nintendo DS Lite Console
Shuts off when you touch the touch screen!
I've just replaced the bottom screen, and didn't notice the fault at first... the touch screen works if you tap it lightly... but if you give it a medium tap with your finger it powers off, and I can use the a button etc fine. Can anyone suggest what the problem might be?
    Problem Solver:
  • 5 Answers
Im guessing that your replacement screen is metal backed (the original had a poly-foam backing for a reason) ,,,, when you tap lightly it works, when you press hard your pressing the metal back of the screen onto the mini-board behind it and shorting it out
If you keep doing this you will damage the mini-board, take it back out and cover the metal back with sellotape or masking tape making sure to cover the whole metal back, (dont go up the sides or its impossible to get back into the cover).
Re-assemble as before and if it isnt too late for this you will have a working DS again.
Hope this isnt too late
Posted on Nov 16, 2007
Touch screen not working for pioneer avh-p4300dvd
you have to clean the debris out of the gap on the bottom of the screen
Oct 09, 2012 | Pioneer AVH-P5700DVD Car DVD Player
I switch my touch screen since it cracked but when i put everything back and turn the phone on, the screen wouldnt light up or anything but the phone still work
The one who replaced didn't fix it well, try to return to him or check another dealer. Maybe it's bad copy of touch screen, or he didn't connect the LEDs
May 16, 2012 | HTC Aria Cell Phone
Touch screen is not responding and can not play any games.
Perform a recalibration as soon as you notice a problem, to prevent performance errors.
If the calibration problems do not go away you may need to contact Nintendo for technical service or if you think you can replace the screen you self i can give the process to do so...
How to Replace a Nintendo DSi Touch Screen
Finding someone to fix a Nintendo DSi touch screen can be time-consuming and costly. However, with the right tools, you can do it yourself. Even if you've never tried fixing anything until now.
things you'll need:
* Tri-wing screwdriver
* Precision Phillips screwdriver
* Precision flathead screwdriver
* New Nintendo DSi touch screen
Turn the Nintendo DSi over and find the five screws on the edges of the bottom. Take each one out with your tri-wing screwdriver. In the center you will find an additional screw that will need to be removed with a precision Phillips screwdriver. This keeps your battery in place.
Take the battery out. Underneath it you will find two screws that must be removed with the tri-wing screwdriver. After both have been taken out, pull up on the bottom casing to access the motherboard. In order to replace a Nintendo DSi touch screen, this will have to be removed.
Detach the right and left buttons in the top corners by pulling up. Underneath each one will be a spring---make sure you don't lose these. Then remove the four screws in the middle of the motherboard with the precision Phillips screwdriver.
Look for the ribbon attached on the bottom left corner of the motherboard. Take a precision flathead screwdriver and pull up on the black bar that connects the ribbon. You should be able to slide it out by pulling back.
Find the two small connectors that are locked in with two tiny clips on each one. Lift up on all four clips to pull out the underlying connectors. Take out the motherboard and turn it upside down. Now you are ready to replace your DSi touch screen.
Detach the Nintendo DSi touch screen with your fingernails. Pull it away from the adhesive, one side at a time. Take the new screen and peel away the protective plastic before replacing it. Line it up where the old touch screen was and reassemble the Nintendo DSi.
Hope it helped...
Aug 15, 2011 | Nintendo DSi Blue Console
Both headlamps won't come on on 06 Touareg. dash light says check headlamps. is it possible that both of them could go out at same time? I'm sure it's quite expensive to repair or replace.
It is very possible you could've running with one burned out for a while and didn't notice uad a power serge or it's possible you have been running with one out for a while and didn't notice till the other went out. Try turning on the high beems if they work replace the bulbs..
Jul 16, 2011 | 2006 Volkswagen Touareg
Touch screen doesn't work
You will need to replace the touch screen to get it to work. This is a common problem with the Lg VU
Check out the following link for a video on how to do that and links to buy a new touchscreen.
Repair LG VU CU920 Touch Screen
Jun 15, 2010 | LG Vu CU920 Cellular Phone
Bottom touch screen has coloured vertical lines all over it
the colour fault is the bottom lcd screen but you may need a touch screen aswell if its been stood on it may be damaged have you tried touching the screen when its powered up to see if it works as this would eliminate the touch screen.
Jul 11, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
