Question about Maytag Neptune MAH6700A Front Load Washer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
  • 1,869 Answers
The door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
Posted on Jun 09, 2009
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Maytag neptune washer clothes staying wet after cycle
    Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
    Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
    Hello there
    The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
    Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
    Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
    Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Front Load Maytag Neptune won't spin.
    check the board
    is the resister thats burning r-11
    if it is you need to change the wax motor lock as well
    its the door lock found where the door latch goes in
    ive included the part number 22002119
    they should have told you
    Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Won't drain all the way and door lock won't light up
    Clean out the drain pump and check the pump motor while it is dis-assembled.
    Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune front load has Lr on Time display
    Im having the same problem what is the lr code and how do you get rid of it?
    Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Door Lock
    on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
    Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune front load
    sounds like possible blocked internal filter or partial pump blockage
    Dec 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
    MAYTAG NEPTUNE
    Not sure if you solved this one yet..but ...
    d5 - Door is open during washing
    I have some more codes for a Model # MAH6700AW if you need them.
    Nov 04, 2007 | Maytag MAH6700AWW Neptune Front-Load...
    Maytag Neptune MAH6700A Front Load Washer Logo
    276 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
