Question about Altec Lansing AHP712i Consumer Headphones
Wire loose My headphone wires are loose right inside where they enter the earpiece. I have the AHP712i headphones. Can I split the headphone apart to get to the wire or will it break the plastic?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Altec Lansing Master
  • 1,001 Answers
  • High quality,guarantee you enjoy a clear sound in noisy occasion.Powerful rechargeable battery provide 5 hours of Talking/Playing time. Rubber adapters, unique flexible design and custom earbuds ensure you get it perfect fit and remain stable in your ear
Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Bule...
Posted on Dec 14, 2016
    President:
  • 1,137 Answers
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
Posted on May 13, 2009
Hesh DJ headphones a wire has come undone so only one of the ear pieces work. if i move the plug in about it crackles a little
Sounds like the wire that came loose is still making contact, but only when you move it around. If you can, take the earpiece apart and you will find a red or black wire shielded by braided wire. Cut the wire back some and resolder in place.
Jul 09, 2011 | Vacuums
I got these headphones and they were working perfectly but one day the right side just stopped working. even after plugging it into my ipod and laptop the right side still doesnt work. what should i do?
The wire carrying the signal to the right side has probably been damaged. You have to be careful with the wires and should not wind them up too tightly. Try seeing if you can get a sound by moving the wire close to the point where it enters the right earpiece. If you can, then it may be possible to resolder the broken connection to fix them otherwise, I'm afraid you'll have to get a new pair of headphones
May 17, 2011 | Sony MDR-RF970RK Headphones
Sound went out on the right side of earphones
See my tip on dodgy cable/plugs on headphones.
Jul 10, 2010 | AKG K 240DF Professional Headphones
High. My earphones don't have any sound at all.. What do I do? The cable seams to be fine.
Hi, what makes the earpiece not working, is that the wire inside the speaker area where you put inside the ear is faulty.
Loose the head of that small speaker, you will see the wire that has removed, use a soldering iron and a lead to fix it back.After fixing back, you can start using it again.
have a nice day.
Apr 29, 2010 | Koss KE29A Isolating Earbud (Aqua)...
Only one ear working
have a nice day.
Apr 29, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Left earpiece has no sound.. can that be fixed?
either theirs something that happaned to the wire like it got stretched out and the inside braided wires pulled apart or came disconnected from the piezoelectric elements, or you have blown the side out.
Dec 21, 2009 | Bose in-ear headphones - Black with...
Can I take apart the logitech A-00006 headphones easily.
The padding comes of easily, hook your finger under from the inside and push out gently. Once removed reviles 2 philips screws. Once they are removed you have to pry the 2 plastic disks that form the swiveling ear piece apart. Then you have access to the speaker, which is glued down with a still very sticky substance but will come up quite easilly, then remove the screw from directly under the center of the speaker, then you can pop off the swiveling earpiece that is on a kind of ball and socket joint, this took quite a bit of force. This is as far as i'm going as I now have access to the damaged part of the wire! And also the 4 screws mentioned in the original question. Hope this helps.
Dec 08, 2009 | Logitech Bluetooth Wireless Headphones
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Altec Lansing AHP712i Consumer Headphones Logo
295 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
