Question about GE SmartHome (58173) 2-Way Radio
One radio makes loud tone when other radio transmits
I have to apologize beforehand because I am clueless with this stuff. Here's the situation: We have a set of GE 2-way radios and they were working just fine. Then, we turned them on and they worked for about three minutes, we talked maybe twice, then the 1st radio began emitting a loud tone whenever the person on the 2nd radio pushed the button to talk. The 2nd radio works fine and can receive voice from the 1st radio. And, the 1st radio can transmit voice to the 2nd radio. But, you just cannot hear anything on the 1st radio but this loud tone when you push the talk button. I've tried changing the batteries and it didn't make any difference and I can't find the instructions that came with the radios. So I'm hoping someone out there can tell me if this is a fixable problem and what we can do. Please help? Thank you for reading my post.
  • 21 Answers
You may have a defective radio that has a bad push to talk switch which doesn't mute the receiver and feeds back audio to itself or this could be a bad solder connection or a broken wire inside.
Not much you can do except replace it or have a tech look at it.
Posted on May 11, 2009
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
Jan 20, 2015 | Generic Walkie Talkie BAOFENG BF-888s Two...
Stop the sound of a Tone when Keying to Transmit..
That generally means that it's set to transmit on an invalid frequency.
Jul 26, 2013 | Motorola TalkAbout T5530 2-Way Radio
CB Humming loudly when not transmitting, but recieving
You probably will have to dig into the unit to find out what's causing the hum.
The 5-pin connector is a mike connector, not a DIN
Jul 03, 2013 | Radio Communications
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Sep 13, 2012 | Generic Walkie Talkie BAOFENG BF-888s Two...
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
If it's a distinct "tone" like 1000Hz, it's probably mis-programmed. Check www.mods.dk. You may find a manual there.
Mar 20, 2010 | Kenwood Radio Communications
Hi there i have a strange icon in one of my radios
The icon you are describing is the "roger beep" icon. It would not be the reason your radio is not transmitting. Most likely your programming has been changed. Here is a link to the manual where you can read how to program the radio's frequency and interference eliminator code. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Roger Beep/Talk Confirmation Tone
When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.
• To enable Roger Beep/Talk Confirmation Tone, press and hold + (plus button) as you turn
your radio On. Now, when you release the PTT button, your set tone lets your
friends know you’re finished talking and will appear on the display.
• To disable the Talk Confirmation Tone feature, turn your radio Off and then back
On while pressing and holding the + (plus) button.
Jul 01, 2009 | Motorola Talkabout T5420 (14 Channels)...
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 11, 2008 | Motorola Talkabout T5100 (14 Channels)...
No audio but transmits ok
Hello dgbuhl,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.)
In order for your radios to communicate with eachother all of the radios need to be on the same channel and have the same CTCSS / Privacy Code programmed (or the CTCSS feature must be disabled on all the radios). If CTCSS is enabled on one of the radios, but not the other, the situation you describe would occur.
Check your user's manual for more information on the Privacy Tones and how to set them.
Best Regards,
Ken
Go Ahead. Use Us.
May 12, 2008 | Cherokee FR-465 (14 Channels) 2-Way Radio
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
GE SmartHome (58173) 2-Way Radio Logo
107 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
