Question about Compaq EVO N600C (Refurbished) 14.1" LCD Monitor
Sorry to as such a simple question, but how do I copy and paste using the Evo n600c? Thanks
    Sniper:
  • 79 Answers
Easy question. you are right.
Say your copying a picture or text, using the mouse select the pic or text you want to copy. Then do one of the following:
1.Go up to edit seelect copy/cut/paste from the menu.
2.Use the right mouse button on what you have selected and select copy/cut/paste.
3. or if you like keyboard shortcuts, use this method...
ctrl+x to cut
Posted on May 11, 2009
  • David Weaver
    David Weaver May 11, 2009
    The rest of part 3.
    ctrl+x to cut, ctrl+c to copy, and ctrl+v to paste
    Sorry for the repost, but I hit something on the keyboard which made this post before I was finished with number 3.
    Champion:
  • 381 Answers
Hi...it is Ok about the question...if u need to try and make copy files just right click the folder or files then click copy then paste what u want location need to copy..GOOD LUCK...Thanks...^_^
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
N600c laptop manuals
Go on this site and download it...
http://pdftown.com/Compaq-Evo-n600c-Service-Manual.html
Jun 23, 2009 | Compaq EVO 600C Notebook
Remove hard drive
it's a really risky operation if you put one component in the wrong spot your whole computer will get fried i would advise that you didn't pull it apart my suggestion is that if you really need to pull it apart take to an I.T consultant sorry...
Jun 06, 2009 | HP Compaq Evo Notebook N600c
Evo N600c follow-up
I hope you got this issue resolved,I was unable to find anything else that would explain the issue or the fix.
Sorry I couldn't be of more assistance
Please rate this fixya
Jan 12, 2009 | HP Compaq Evo Notebook N600c
Need help with Evo N600c battery Pack
Wouldnt fancy taking one apart myself, replacement ones are not very expensive, look here on battery trader , Compaq Evo N600c laptop battery
Dec 08, 2008 | HP Compaq Evo Notebook N1000c
TV Out
You want to use a S-Video cable to hook up the laptop to a TV. To send the signal to the TV typically you want to use Fn F5.
Jun 04, 2008 | HP Compaq Evo Notebook N600c
Reboot
You can insert the OS installation CD and hit F11 or F12 to get to the boot menu. The you can wipe out your hard drive and put a fresh copy of windows on it.
Apr 18, 2008 | Compaq Evo N600c Notebook
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Open Questions:
Save Your Important Data Getting Lost With Cloud Backup Solution of Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 26, 2018 | Individual Computers & Internet
See all Compaq EVO N600C (Refurbished) 14.1" LCD Monitor Questions
Compaq EVO N600C (Refurbished) 14.1" LCD Monitor Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
