Question about Troy Bilt 5.5hp Self Propelled Mower
Will not crank due to oil overflow
I over filled lawn mower will oil and now it will not crank. I drained the oil out and it still will not crank.
  • 15 Answers
Sounds like you may have gotten oil into the cylinder past the piston. If this is the case, just remove the spark plug and spray some carburetor cleaner inside, then blow air into it. Try to turn over the engine with the plug still removed and cycle it a few times, then give it a short squirt of WD-40 and reinstall the plug...and try to start it. I hope this helps.
Posted on Jun 17, 2009
  • 351 Answers
You may have got oil up into the combustion chamber if you have tipped the mower the wrong way, remove the plug and check
Posted on May 12, 2009
Eliminate smoke
Drain fuel tank. Fill with fresh and add the correct amount of the correct oil.
Take the old fuel, and add it to your car's tank, it should be diluted enough so your car will be fine.
Jul 07, 2016 | Garden
Hi I have a Craftsman Lawn Mower 225 and i bought a 40w oil and put in it and it started leaking and ommiting huge white smoke. what should i do?
Hi Manny First thing is Drain all the oil back out. You have most certainly overfilled it. Try and get as much out as you can from the same place you filled it from. Leave it tilted back until it stops running and then put the mower level for half an hour. Check the oil level now and clean the spark plug and replace it. There will still be oil in the air filter due to over filling. Only put oil in one egg cup at a time until its below max on the dip stick. Run the mower for 20 minutes and burn the smoke off. It may smoke for a few times but thats ok.
Aug 24, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Where is the oil plug on a lawn mower? We have found the oil but can't find the plug to drain it
Many of the newer lawn mower engines do not have a drain plug anymore... to drain the motor you will need to dump them upside down and run the old oil out of the fill pipe....yeah, it's dumb, but I bet 95% of the people never drain their oil....
heatman101
Sep 05, 2011 | Garden
I put too much oil in my lawn mower and when I start it up it smokes
Hi patsy hale...
You need to drain the over fill of oil out of your mower, if not it could damage the engine, if it has not already done so.
If you have a drain plug it will be on the bottom of the engine under the mower housing.
Remove and drain out until you reach the right level the oil should be at.
If you do not have a drain plug under the mower then you will have to tip the mower over on its side with the oil fill plug out and drain the excess oil that way till you reach the proper level.
I hope you have not done permanet damage already, if it still smokes after a a few minutes of running then you do have major problems.
Please take time to rate me
Sep 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How much oil should I put in my toro self propelled briggs & stratton lawn mower
if your motor doesn't have a dip stick fill the oil to the sight ring inside the fill tube, try and not overfill , this will cause seals to blow out due to increased pressuer
Jun 20, 2011 | Toro Power Lawn Mower
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
Can't locate oil change plug
On most of these mowers the oil drain plug is on the bottom of the motor, under the deck. Remove the spark plug wire just to make sure the motor doesn't fire if you have to turn the blade to get access to the plug. Turn the mower on its side with the carburator down so you don't fill the crank case with gas. You may have to scrape or power wash some of the grass/dirt buildup on the bottom of the motor to find the plug. Remove the drain plug and let the mower down so the oil can drain it. When it stops draining, replace the plug, refill the crank case with oil to the full mark on your dipstick, replace the spark plug wire and you're done.
Mar 21, 2011 | Poulan Pro 22" Self Propelled High Wheel...
How do I change the oil on my poulan push mower?
First: Disconnect the plug wire from the spark plug. Safety first. Second, look under the mower deck where the crankshaft comes out of the mower (where blade attaches). Right next to the crank shaft should be a drain plug. Remove the plug, drain oil in a pan, replace plug, put mower back on level surface, and refill in the fill plug on the topside of the engine/deck. Don't forget to reattach the plug wire when you are done.
May 28, 2010 | Poulan "Poulan" Push Mower
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
My yard man mower is blowing black smoke when I crank it. Why would this be?? It was low on oil, but we filled it up and it still smokes. Do we need to change the oil? If so how? It has a honda engine, and...
Like the other guy says drain the oil out. Disconnect the spark plug wire (for safety). Place the mower onto a stable platform to work from. To remove the drain plug usually you need a 3/8 ratchet and I use a short extension so I don't skin my knuckles. Put the extension end into the drain plug and remove. Have a drain pan to catch the used oil. Clean the area around drain plug first. When oil is drained replace the drain plug and tighten. Add your new oil. ONLY ADD ABOUT 15 OUNCES. Use SAE 30 motor oil. Once you get the oil in set it on a flat surface and check for the proper level. Add if needed. Usually the push mowers only use about 16 ounces. I start with 15 because it is easier to add than remove the oil. Replace the spark plug wire, prime and start. It may smoke awhile to get the old oil burnt up.
Aug 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy Bilt 5.5hp Self Propelled Mower Logo
107 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
