Question about RCA F27442 27" TV
Rca f27442 input button not working
I normally use the input button on the remote to switch over to my dvd player that is plugged into it.. For some reason now, when i hit the input button, it does not switch over. It only flashes up on the screen a blue vchip lock and cc box. (icon like). the display button does this same thing. how do i get my input button back to functioning normally?? thanks.
    Problem Solver:
  • 7 Answers
REset your parental rating.
Posted on May 11, 2009
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
F27442 - How to display signal from front panel RCA video input
To display signal from that input you will need to change the input on the tv. This can be done either on the front of the tv, or by using your remote control. First power on and connect the desired source. Next on the tv or on your remote, press a button labeled either source or tv /video and scroll through by continuously pressing until you see the source you connected appear on the tv display.
Good Luck
Jan 07, 2011 | RCA F27442 27" TV
Bought a universal remote and input button does not work
You will have to find an RCA universal remote. Please search your local discount store and find an RCA remote with input. This is what you'll have to do...sorry!
May 08, 2010 | RCA F27442 27" TV
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Have set up a new SONY DVD player. How do I set my RCA Cable TV so I can play a DVD. My Channel Code is #3 on the TV
use the color coded wires that were supplied with the DVD player plug them into the inputs on your rca tv then use you remote and there should be a button that says input i know my rca tv does. Then you push this button and it lets the tv use the input plugs.If there is more than one plug in on your tv push the button till you see your DVD players on screen menu.
God Bless Greg
Nov 15, 2008 | Computers & Internet
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
May 24, 2008 | RCA F27442 27" TV
Television trouble
Might it be that you changed the input? Try pushing the input button on the remote.
Hope it helps...
Mar 04, 2008 | RCA F27442 27" TV
RCA F27442 27" TV to Sony NS300 DVD Player
Rex,
here's a site that should be able to answer all your questions regarding coding a remote to a device...
http://www.remotecodelist.com/remotes/
Bill
Feb 21, 2008 | RCA F27442 27" TV
RCA F27442 27" TV Logo
257 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
