Router greatly slows up/downloads to 25% of direct from modem
I'm using a LINKSYS WTP54G wireless router with a sharkfin modem. I got this router to work with my Vonage service. The router slows my up/downloads to under 1mb. Direct to the modem it's over 4mb. Suggestion for a faster router that works with Vonage? LINKSYS tried tweaking my router, no success. This thing's gotta go! Thanks in advance.
  • kayakerles May 12, 2009
    Thanks. A suggestion for one that doesn't chop down what's happening is what I was looking for! I'm using a Macbook Pro with Leopard, (10.4), a Fujitsu laptop with XP Pro, and an old desktop with XP Home. With modem alone I was at 7.3mb dowloads! With the LINKSYS router WITH updated firmware... 467kbps. Ha! No Hulu TV watching there! Thanks.
    However, the Vision doesn't have an RJ11 jack for phone lines. How do you use it with Vonage? Let me know so I can order what I need. ;-) Thanks again.
    Problem Solver:
  • 17 Answers
I am using a Belkin N1 Vision router with Vonage and i am having no issues with speed at the moment. What OS and connection are you using. If its Vista and Wireless make sure you are using AES encryption and not TKIP as my wireless network was painfully slow using TKIP and lightning with AES and WPA2
Posted on May 11, 2009
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I need to download a users manual for Linksys WRT160n wireless Router, Any suggestions
The Manuals are located on the Linksys website:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT160N
Select Downloads, choose your version, and on the right you can download the manual.
Apr 21, 2010 | Linksys WRT160N Wireless Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Running slow
Is it running slow on both wired and wireless connections? how about if a PC is wired directly to the modem? That will eliminate the router as the issue (slow internet could be your modem or the connection itself).
If you're sure it's the router (wireless and wired) then upgrading the firmware would be first step. You can download the latest firmware from linksys.com and get it installed via the web interface of the router (probably found by going to http://192.168.1.1).
If a firmware update doesn't do it you can change your DNS servers from being automatically detected from your ISP to public ones. This may help web pages load faster. You can enter them also using the web interface. Set the Primary and Secondary DNS address to the numbers below (they are from OpenDNS.com).
Primary 208.67.222.222
Secondary 208.67.220.220
Jan 26, 2010 | Linksys WRT120N Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Slow downloading movies,grtting on internet
Try downloading movies when your pc is directly connected to your modem. If connection is very much faster then upgrade the firmware of the router.
Good Day
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
