Question about Heavy Machinery
Chipper won't start
My yard machines 6.5 hp chipper all of a sudden won't start. It appears to have no spark. I haven't taken anything apart yet. I did take the fuel line off at the carburetor and fuel started running out. It looks to be a gravity fed carburetor. I took the plug wire off, removed the boot, placed the end of the wire near the spark plug and pulled the starter cord a couple of times, no spark. Does it have a coil or something similar?
  • 462 Answers
What engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
Posted on Jun 05, 2009
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
5hp chipper will start and run only with the choke on and has no power, please, help.
sounds like the carb is gummed up. You probably need to do a complete carb cleaning.
Aug 07, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I need a owners manual for a 10 hp chipper schreddermodel 24a464g729 serial no. 1io14g4o175 i think i may need blades
Go on line to " PartsTree.com" Start your search by clicking on MTD. Go to chipper/shredders, and fine your Model number, It's listed. In the search window- type in chipper blade. Also, on the drawing schematic of the machine, the blades are # 31 in the list of parts. I looked up the 2005 model. There are are few years with the same Model #.
Jul 14, 2009 | Mtd Products Yard Machines 158CC Tiller
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Briggs & stratton chipper wont start
I believe it is part of the systen shut off. Should be connected to the motor (ground).
Hope this helps you
Kurt
Mar 18, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
Mar 14, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 02, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Heavy Machinery Logo
607 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
